Intake Advantage With New Hood?
Old Jan 8, 2004 | 02:27 AM
350 PILOT's Avatar
350 PILOT
Default Intake Advantage With New Hood?
If I got the Veilside 3 hood is there anyway to take advantage of the "cleaner" air coming in the scoop?
Attached Thumbnails Intake Advantage With New Hood?-veilside-version-3-front.jpg
Old Jan 8, 2004 | 04:31 AM
teh215's Avatar
teh215
Since the scoop is way behind where the stock air intake opening is, you would have to make you own intake tubing and relocate the MAF, filter, etc.. It could be done but it is going to be rather expensive for all the more gain you might see out of it. Keyword here is might.
Old Jan 8, 2004 | 07:23 AM
FairladyZ's Avatar
FairladyZ
If the hood is functional, you would benefit from the hot engine heat being vented from your motor and cold air to help cool it.
Old Jan 8, 2004 | 07:24 AM
Wedge's Avatar
Wedge
I think you are already taking advantage of the scoop. The air coming in through the scoop will keep the engine bay cooler and therefore the intake pipe will not absorb as much heat. This will keep the air coming in through your intake from becoming warmed while in the pipe.
Old Jan 8, 2004 | 09:51 AM
350 PILOT's Avatar
350 PILOT
I read that the scoop is functional, but I don't know if that means all three scoops or only the center forward facing scoop. If they all were functional looks like a guy could use the driver's side scoop pretty easily. I am also concerned about rain water. How did they keep rain out of other scoops?
Old Jan 8, 2004 | 09:55 AM
FairladyZ's Avatar
FairladyZ
On my ls1 there was a plate in the "nostrils" that diverted the rain water down and out. I think that is for show mostly.
Old Jan 8, 2004 | 11:35 AM
boyze's Avatar
boyze
Is the hood CF and/or FG? If so, your engine may actually run a bit warmer even if the scoops are functional, especially in idle and slow speed cases. The plastic is a poor heat conductor relative to the stock aluminum hood.
Old Jan 8, 2004 | 12:25 PM
Hey Ya's Avatar
Hey Ya
Maybe I'm just not thinking clearly today, what's FG?
Old Jan 8, 2004 | 12:41 PM
350 PILOT's Avatar
350 PILOT
Its FG (fiberglass)
Old Jan 8, 2004 | 12:45 PM
Hey Ya's Avatar
Hey Ya
Originally posted by 350 PILOT
Its FG (fiberglass)
Ah yes, thanks!
Old Jan 8, 2004 | 01:01 PM
350 PILOT's Avatar
350 PILOT
That "FG Response" also was meant for BOYZE
Old Jan 8, 2004 | 07:51 PM
350zdanny's Avatar
350zdanny
Doesn't Mine's make a "vent" that you can install in the bumper to act as a sort of ram air system? That would be much easier than rerouting any intake piping, even if you had the proper clearances.
apex locator
Jul 23, 2021 02:27 AM
Sleeper_Z
Sep 30, 2015 10:25 AM
Extreme Dimensions
Southern California
Sep 24, 2015 03:35 PM
