Borla install question
Old Aug 17, 2012 | 09:36 AM
Guerilla350's Avatar
Guerilla350
Default Borla install question
Just picked up a Borla TD exhaust for my 03' 350z. It came off of a 04' g35, I believe the only difference is the g35 is longer, correct?
I was told I would need an adaptor for it to work, does anyone know if that is correct before I go buying parts I don't need?
Thanks everyone
Old Aug 17, 2012 | 09:55 AM
AdvanZ33's Avatar
AdvanZ33
Senior Super Moderator
Thanks everyone
The G35 exhaust is longer and uses extensions to run 350Z exhausts. However, the Borla part numbers for the G35 and Z are different so it looks like you're going to have to cut and weld your exhaust to make it work. I would suggest taking the whole exhaust to a muffler shop, tell them it was made for a G and could be too long. I'm sure they will find the issue during installation.
Old Aug 17, 2012 | 10:05 AM
Guerilla350
I just called a local exhaust shop and the guy was a complete idiot, he said it's impossible to run a dual exhuast on a 350z....nvrpgheanffmzcxvnafljlq.........i agree, i'll probably need to bring to a reputable shop to figure it out.
Old Aug 17, 2012 | 10:20 AM
AdvanZ33's Avatar
AdvanZ33
It may just be a matter of cutting the 2 pipes that connect to your catalytic converters 3" or so.
Old Aug 17, 2012 | 11:42 AM
JERZ350's Avatar
JERZ350
Yea isnt it just the H-pipe? The G's H-pipe is longer, you need the shorter one, or cut the one you have. Any exhaust shop should be able to do this.
Old Aug 17, 2012 | 11:49 AM
cubs4worldseris's Avatar
cubs4worldseris
Life aforementioned, take it to a reputable Z/G shop. They will make easy work of it.
Old Aug 18, 2012 | 06:50 PM
Guerilla350
All worked out well, they just had to cut it a little shorter to make it fit. Im a little disappointed in the sound. I like it to be a low, subtle growl but it's almost not noticeable at idle (in the car). Im sure a couple of high flow cats might do the trick.
Thanks for the help, I appreciate it
Old Aug 18, 2012 | 10:22 PM
F2CMaDMaXX's Avatar
F2CMaDMaXX
Glad it was worked out, but high flows won't make it deeper, just louder and crisper.
You'll need something like ART pipes for a deeper tone.
Old Aug 20, 2012 | 10:07 AM
JERZ350's Avatar
JERZ350
Yes, at idle it's as loud as stock. I have borla, i also recently put BERK HFCs and it definitely amplified the sound. It's the same sound just louder.
Workshop12
Mar 23, 2020 01:45 PM
JjL
East Canada
Jun 12, 2019 03:04 AM
Suffolk350z
Sep 13, 2015 02:43 PM
