Suggestions for an exhaust system? '03 350z
There are quite a few videos on youtube and other various sites with sound clips. Doing a search on here will also reveal quite a bit of info with reviews on all of the exhausts you posted.
Of the 3 you listed, Borla is probably the deepest/lowest. But it is also probably the most quiet. After it warms up, at idle, it doesn't sound a whole lot different than stock. It sounds nice and deep while under load.
Do your own research Joyce Feng. A simple search on this forum or on Google will yield numerous reviews detailing just about every exhaust system available on the Z platform.
/thread
/thread
Motordyne Shockwave TDX2 and ARTs will probably give you the most aggressive sound, loud, but controlled. Borla will be deep and the quietest, no rasp. But Borla's H-pipe will make a hiss sound during downrev's (when you let off the gas). Pairing up the Borla with high-flow cats will amplify the Borla's tone. But it will also amplify the hissing sound.
I have BERK HFCs paired with my Borla and there is absolutely 0 rasp.
You can eliminate the hissing by installing a Magnaflow X-pipe in place of Borla's H-pipe. There are a ton of threads about it here.
Keep in mind if you go the Borla route, it comes in many pieces and clamps. Make sure you install it correctly or you will have exhaust leaks. Also make sure the exhaust hangers have plenty of clearance. As the system heats up the rear hanger near the muffler can make contact and rattle.
lolwatbro
Oct 9, 2021 04:58 AM
m_0g
Jun 3, 2021 10:05 AM
bcoffee20
Nov 19, 2015 06:39 PM
