Injen Heatshield
Old Jan 12, 2004 | 09:09 PM
mofoz's Avatar
mofoz
Unhappy Injen Heatshield
When me and my buddy(a mechanic) installed some parts for my Z this weekend, we really couldnt figure out where to put the heatsheild for the intake. the directions as you know if you have bought one are pretty bad, and the pictures were blurry. If anyone has any pics, i would like to put this thing on, but we stared at the engine for like 10 min and couldnt figure it out. Thx
Old Jan 12, 2004 | 09:10 PM
mofoz's Avatar
mofoz
i did mean to post this in the engine section. sry
Old Jan 12, 2004 | 09:41 PM
Sosa's Avatar
Sosa
I think it's only used when you setup the intake as a short ram.
Old Jan 12, 2004 | 09:43 PM
islandsnow's Avatar
islandsnow
i'll try post a pic later, but the 2 screw holes are way down there. I forgot but i think they are like on top of the stock exhaust manifold. once you try to position the heat shield down there it makes sense since you have to line up the screw holes.
One screw was easy with an extension the other you needed some small hands to get down there.
Old Jan 12, 2004 | 10:11 PM
MY350Z.COM's Avatar
moved
Old Jan 12, 2004 | 10:51 PM
mofoz's Avatar
mofoz
ya some pics would help alot, i figure i paid for it might as well put it on.
Old Jan 12, 2004 | 11:03 PM
03 Z for ME's Avatar
03 Z for ME
It's actually pretty simple. (Sorry I am at work now, don't have a camera or the Z here to take a picture.)
Just slide the heat shield down the side of the engine compartment over the top of the exhaust manifold. You will easily see exactly where it goes. Getting the front bolt is no problem. The back one is a real biatch... (hope you have small hands)
Old Jan 13, 2004 | 02:34 AM
abstrakt's Avatar
abstrakt
the spot is right underneath the upper tube...
Old Jan 13, 2004 | 04:27 AM
pimp1911's Avatar
pimp1911
I have a long ram setup. And I use it. A pain the *** to put on but I used it.
Old Jan 13, 2004 | 09:02 AM
FairladyZ's Avatar
FairladyZ
Its actually easy to install with the right tool. It goes over the stock heat sheild that covers the manifold/header.
Old Jan 13, 2004 | 10:56 AM
ttsupra94's Avatar
ttsupra94
It took me like 10 minutes to put that thing on, only problem was that one of the bolts got stripped and couldn't get it out. After we had it removed it was very easy to put the heat shield on.
Old Jan 13, 2004 | 08:54 PM
islandsnow's Avatar
islandsnow
damn, sorry i forgot my dig cam at my friends house. If you can wait till the weekend, i'll take a pic then. If not, i'm sure you can figure it out by these posts. I didn't have a problem with mine, but when you install it, make sure it doesn't rub against the AC pipe, some people claim it'll rub while the engine is running and cut through the AC aluminum hose and cause a (freon or whatever that stuff is now) leak.
Old Jan 13, 2004 | 09:28 PM
mofoz's Avatar
mofoz
ya, if you wouldnt mind posting them, i will try putting it on next weeknd most likely. thx.
Old Jan 14, 2004 | 06:01 AM
FairladyZ's Avatar
FairladyZ
Yep we had to grind mine looks very clean. (off the car) The other one we bent out. (on the car)
Old Jan 14, 2004 | 06:53 AM
350zdanny's Avatar
350zdanny
Is it meant to be used with the CAI setup or just with the short ram?
Old Jan 14, 2004 | 08:05 AM
FairladyZ's Avatar
FairladyZ
it doesnt matter it blocks the heat from the exhuast manifold. You could use it with the stock intake if you wanted.
Old Jan 14, 2004 | 10:24 PM
Jun's Avatar
Jun
Here you go man, i installed mine right after christmas. I couldn't find it either, so i was going to make a how-to guide and took some pictures
If you need help let me know.
Here is a picture of the stock heatshield (yellow), it is located (if you are facing the engine) to the right of it, you can tell where it is from this picture, to the right is the strut bar. Think of it as a cover for the right header and you'll get the picture. There are two bolts (1 &2):
Bolt 1 (front) again:
Bolt 2 (rear) again:
Take both bolts out, place the Injen heatshield on top of the other one, and reuse the bolts to tighten it back in place. Here is the Injen heatshield in place (yellow):
A better angle of where it is (i took the strut bar out because it was easier for me to put the aluminum part of the intake in place, i don't think it's necessary, but it just made it easier for me):
And one more:
Hope that helps.
A couple tips:
1. If you can remove the bumper, go ahead and do that, it facilitates taking out the ramair duct out as well as installing the coldair portion of the intake.
2. If you DO decide to remove the strut, be careful, it is on tight, i had to twist one turn to put it back on, so i don't know if i have the same rigidness as before.
3. In the installation instructions it mentions to position the MAF sensor UP, mine is not completely up (90 degrees), but i would say more of a 45 degree angle leaning to the right.
Old Jan 14, 2004 | 10:32 PM
mofoz's Avatar
mofoz
ya i installed the whole intake and just left the heatsheild off, but i will probably one of these days put it on. Maybe this weekend, but who knows. Thanks for the pictures, cause i dont think i would have ever found it.
Old Jan 15, 2004 | 04:46 AM
FairladyZ's Avatar
FairladyZ
find someone close to you to put it on. It is so easy like a 10 min job.
Old Jan 15, 2004 | 08:41 AM
arvin's Avatar
arvin
I did not install my heatshield. Do you guys think it is very important?
