Decions suck. Please help. Test pipe....
Old May 11, 2013 | 10:50 AM
2007base350z's Avatar
2007base350z
Question Decions suck. Please help. Test pipe....
I am so close to buying Berk test pipes I have stock exhaust with Injen CAI and some other random stuff like stage 2 clutch, willwood master, and heavy duty slave.
At the moment I dont have enough $$ for a tune so are my hopes for test pipes smashed?
If ANYONE would help with some pros and cons. Would be awesome. Yes I know its going to be loud.
Old May 11, 2013 | 11:29 AM
Bmurray350z's Avatar
Bmurray350z
get an exhaust first... un-resonated test pipes with the stock exhaust sounds like a$$. but to answer you question, no running test pipes with out a tune is fine unless you do it for a long time.
Old May 11, 2013 | 01:13 PM
2007base350z
Question
any other opinions
Old May 11, 2013 | 02:01 PM
labelworkshop75's Avatar
labelworkshop75
Old May 11, 2013 | 07:11 PM
ian99rt's Avatar
ian99rt
I would absolutely suggest a cat back first. Test pipes without the will do nothing but eat gas mileage (thanks to CEL).
My car with injen intake and cat back was running around a little lean (14.0 AFR at WOT), uprev tune is now around 12.7 AFR.
Soon will be putting on resonated test pipes and fully expect to need some tune tweaking.
Old May 12, 2013 | 11:40 AM
Phenom's Avatar
Phenom
Toasty
You'll be fine. Berks are a good choice. Better than anything resonated IMO. Id get an exhaust to go with them at some point and then a tune.
Old May 12, 2013 | 03:14 PM
2007base350z
Question
^^ I like the positiveness ^^ I went to extreme autofest last nigtht and met a couple guys from Megan Racing and they said it would be a 2 month wait for resonated test pipes and he would hook me up a pair for 100 bucks worth the wait for get the berk pipes for 180
Old May 12, 2013 | 03:25 PM
2007base350z
anyone?
Old May 12, 2013 | 04:33 PM
2007base350z
bump
Old May 12, 2013 | 11:32 PM
Frostydc4's Avatar
Frostydc4
You can use them but keep in mind you will have a CEL & your car will run lean.
Old May 13, 2013 | 07:09 AM
Phenom's Avatar
Phenom
Toasty
Id get the Berks.
Old May 13, 2013 | 07:19 AM
AshMan's Avatar
AshMan
Club Moderator
the Hot Spot
Who's Decions?
Old May 13, 2013 | 09:45 AM
Deteria's Avatar
Deteria
Appears all your problems could be solved with more $.
I'd just save up if I were you. Do it all at once so it's legit. You get one part now, you still missing another piece to make it all work efficiently.
As others stated above, you'd want a tune. You'll definitely be running lean.
Old May 13, 2013 | 06:14 PM
kyle22's Avatar
kyle22
If you plan on running TP don't install them until you get a cat back as well. For one, paying for install twice is absurd. I ran HFC's without an exhaust once and I assure you it sounds like complete dogsh!t. Work hard and save up your money to do it right the first time.
Old May 14, 2013 | 01:26 PM
travlee's Avatar
travlee
Master
you will have a choke point if you swapped out the cats without doing the exhaust first, the way i did it was got the invidia exhaust, and then kinetix HFC's, and finally got tired of them and got the motordyne ART pipes (shockwave tdx2 coming soon). right now mine sounds throaty without being too loud. if you can afford the $600 get the art pipes, the way they have the bung, (and if you look inside there is just a small hole for exhaust to enter it and only about the size of pencil lead) you shouldnt throw a code. i didnt when i put on my kinetix, but i was also tuned shortly there after
AbrasiveRaysive
Sep 20, 2021 02:29 PM
issyz
Jul 2, 2017 03:04 PM
