Custom 3" Intakes on VQ35HR project....
Old Mar 14, 2014 | 07:36 PM
npr350z's Avatar
npr350z
Add some dem speed holes! Lol
Old Mar 14, 2014 | 07:46 PM
Sick an Twsd's Avatar
Sick an Twsd
Originally Posted by onagao
As stated above, the gains are there, but are ultimately negligible. The only testing I did not get to perform was long-term cruising temperature comparisons. I feel the results would be fairly similar - lower by 1-2 degrees. Since 10 degrees lower roughly equals 1% horsepower higher, you're looking at an increase in the realm of 0.2% horsepower at most. For a car putting out 250whp, that's 0.5whp or less.
So if you're considering installing a duct of this type, your reasons should be primarily aesthetic, as the performance gains from this mod are present, but negligible.
Source: https://my350z.com/forum/intake-exha...e-gains-2.html
Old Mar 14, 2014 | 08:35 PM
npr350z's Avatar
npr350z
They look pretty specially on the v2, with the hr hump! Mmm so sexy! With those enkeis! Sexy sexy z!
Old Mar 15, 2014 | 05:07 AM
rich2342's Avatar
rich2342
Are you going to dyno for results? or 1/4 mile comparisons?
Old Mar 15, 2014 | 05:38 AM
Cux350z's Avatar
Cux350z
hatersgonnahate
So custom diameter maf tube?
Interested in the results.
Originally Posted by 2004Black350z
Going to CIN to drop my car off next week tell Bobby to do your car same day so I can have a ride back lol
What did you finally decide on getting done? You have gone through so many possibilities...did you keep that vortech?
Old Mar 15, 2014 | 08:20 AM
2004Black350z's Avatar
2004Black350z
Exhaust Whore
Sorry for ot but yes vortech v2 3.12 pulley. With my mods should be pretty solid numbers. Also gonna sound faptastic
Old Mar 16, 2014 | 05:18 PM
Bmurray350z's Avatar
Bmurray350z
Originally Posted by Sick an Twsd
Interesting thread..
Yeah.. they're alright. I used to hate how they look, but they have grown on me a little.
More so dyno results. Will probably do a baseline, on the day of testing, with the stillen intakes and current tune, then install the 3" intakes, and do another baseline, then let Bobby start working his magic and see where it takes me.
Old Mar 16, 2014 | 05:54 PM
npr350z's Avatar
npr350z
What's the eta on this mr. Trendsetter?
Old Mar 16, 2014 | 06:09 PM
Bmurray350z
all i have to wait on is cin to make the intake pipes and then i'm driving up there.. so who knows... maybe a couple-few weeks? if nothing else comes up that is
Old Mar 16, 2014 | 07:57 PM
npr350z's Avatar
npr350z
your tb are 60mm right? just asking if your gona open up rest of the intake track a lil bit.
Old Mar 17, 2014 | 06:20 AM
terrasmak's Avatar
I see coolant hoses hooked to the TB, that needs to be removed.
Stock HR is 60 mm, I wonder if a pair of DE TB's would work.
Old Mar 17, 2014 | 07:14 AM
npr350z's Avatar
npr350z
The hr's use the the same connector as the 2k9 maxima. There's premade harness for the de tb to maxima so I guess you'd just need the inverse of it. Female your clip male de clip. And hope the bolt holes line up.
Old Mar 17, 2014 | 07:53 PM
waldo36's Avatar
waldo36
Wonder if the DE TBs will even match the HR bolt pattern? If so, the you'll need a fancy 3" MAF housing. This is what I was looking at before I found the GTM one that had bolt holes that I needed. This style would work perfect for the HR setup, but I don't know the length measurement.
http://www.treadstoneperformance.com...89&cat_key=467
Old Mar 17, 2014 | 08:06 PM
Bmurray350z
I am having 3" OD aluminum pipes made and they're going to weld maf bungs and pcv valve bungs
Old Mar 17, 2014 | 08:41 PM
waldo36's Avatar
waldo36
Gotcha
Old Mar 23, 2014 | 05:43 PM
Bmurray350z
Scheduled appointment on Saturday to get the intakes installed and then get re-tuned.
Going to start by doing another baseline run with the current setup/tune, then install the intakes, and see where it goes. I want to re baseline because i now have the 3.9 final drive. and last time i dyno'd with the 4.08 gears (at the time was making 292whp, 264tq), the car's numbers were down to around 285/259. Bobby said every car that has a shorter gear in it, for some reason, just drops power on the dyno.
The car hit 303whp and 272tq with the 3.5 final drive in.
So basically if my baseline is 290 (where as I hit 303 with the 3.5 fd) and i gain 10whp with the intakes and retune, then i can assume 313ish whp with the 3.5 fd, no?
Old Mar 23, 2014 | 06:23 PM
Bmurray350z
Also -
I'm debating if I want to do intake ducts now..... I found these ducts on ebay. They're similar to the Titek ducts but like $300 cheaper lol.... they're also for the 370z, but i'm sure they would work??
Old Mar 23, 2014 | 06:48 PM
  #38
npr350z's Avatar
npr350z
Do it! Angry snouts!
Old Mar 23, 2014 | 07:39 PM
  #39
waldo36's Avatar
waldo36
I think you're going to be surprised by how much you gain by opening up the MAFs. I truly feel that's been the difference maker for why I'm hitting my numbers for a 5AT DE.
Old Mar 23, 2014 | 07:47 PM
  #40
npr350z's Avatar
npr350z
What size did you go to? What sort of gains did you see?
