Buzzing exhaust HELP!
Old May 15, 2015 | 06:40 PM
Whiteskittle's Avatar
Whiteskittle
Default Buzzing exhaust HELP!
Hey guys I'm new to the forums. I just installed berk test pipes on my 03 350z and I am experiencing a really ricey bumblebee buzzing sound anything over 3000 RPMs. TPs are mated to a stillen true dual catback system. I have read a ton on here about others with this problem, leading me to remove the above-cat heat shields and i have torqued and inspected every single bolt and gasket. Still buzzing. My next move I'm considering is having a custom shop remove the Y-pipe portion of the stillen and custom make an H pipe. I have read that is supposed to work. I have also read that getting a tune would work. Does anybody know a SURE fire solution to this?
Old May 15, 2015 | 07:54 PM
Whiskers1996's Avatar
Whiskers1996
I have the Stillen exhasut and berk tp's also and I dont experience a 'buzz' sound. It is raspy 3.5k-4k ish at partial throttle though.
Old May 16, 2015 | 09:36 PM
Whiteskittle
My mechanic told me it's because you lose back pressure when you straight pipe the z. And he said a resonator would help but I'm convinced something is wrong, especially since you have my same setup without the buzzing. I don't mind the raspy sound but it's a very loud ricer buzz above 3-4000 and I hate it!
Old May 16, 2015 | 09:38 PM
Whiteskittle
I'm going to take some videos and try to post so people can listen. I also have a pretty big dent in the passenger side exhaust pipe right near the y junction. I'm wondering if that may cause it?
Old May 16, 2015 | 09:45 PM
Whiskers1996
Hmm, mine has no dents . I'll probs be getting a gopro within a few days(yay for amazon prime) and ill make a short clip and post it , hopefully that can help you decide whether you think you have a problem or not.
Old May 20, 2015 | 06:42 AM
ZaaronZ's Avatar
ZaaronZ
Exhaust leaks, even the smallest of them, will dramatically change the exhaust tone.
Mine buzzes at a higher rpm, and i couldnt find a leak, so i am thinking mine is the nismo headers and s-tune exhaust together???
Old May 22, 2015 | 08:21 PM
Whiteskittle
Default Audio of buzzing
Old May 22, 2015 | 08:36 PM
nizmo_0385's Avatar
nizmo_0385
Something is loose broken or something. Try to get it on a rack and rev and have someone listen with a scope. Maybe cracked tp.
Old May 24, 2015 | 06:54 AM
Whiteskittle
I will get it on a rack asap. I crawled under to take pictures of the dent. Not sure if this link will work.
sales@czp
Sep 23, 2019 03:30 PM
Justin100
Nov 29, 2015 03:58 PM
nanotech
Oct 2, 2015 05:02 AM
Li1ag
Sep 28, 2015 02:07 PM
