Help to source a 3" MAF housing for DE?
Old Dec 19, 2015 | 01:31 PM
apex locator's Avatar
apex locator
Question Help to source a 3" MAF housing for DE?
Been doing a little research into intake setups and it seems almost impossible to find a larger MAF housing for the DE. Lots of ford housings on ebay but flanges dont match up, and z1 auto is out of business.
Looked at the treadstone products, but I'd have to get a flange welded to bolt up to my jwt popcharger.
I want to change up my intake a bit since I plan on test pipes and a retune anyways. thanks.
ap
Old Dec 19, 2015 | 02:06 PM
Whiskers1996's Avatar
Whiskers1996
Just buy a new velocity stack for the JWT?
http://www.spectreperformance.com/ca...?cat=C00000045
Old Dec 27, 2015 | 01:58 AM
thekyledeg's Avatar
thekyledeg
or get a 4" maf and make a complete 4" intake... good for about 10 WHP.. itll run you about 100 bucks for the whole setup.
http://www.jegs.com/i/Spectre/865/9405/10002/-1
All you need after that is a 6" to 4" v stack, a foot long 4" dia silicone tube and a 4" to 3" 45* adaptor.. can all be had for 100 bucks.
Old Dec 29, 2015 | 09:56 AM
terrasmak's Avatar
Many options to do this are available. All include ditching or modding the Pop Charger
Old Jan 13, 2016 | 12:30 PM
thE33Z33's Avatar
thE33Z33
Interested in this as well. I also have the popcharger and I've been thinking of going up to a 3 inch. Wouldn't going any bigger be useless since the throttle body would be a choke point? Even after the TB, what about the neck of the plenum inside past the TB?
Old Jan 13, 2016 | 01:39 PM
Whiskers1996
From what I have seen there are still slight gains in going larger even with the choke point. I believe I read that from one of 2bad240's old thread and also a few maxima ones as well.
Old Jan 14, 2016 | 07:52 PM
thE33Z33's Avatar
thE33Z33
I can concur with you there as I've by now read similar claims. those maxima guys are apparently making use of the 3 inch land rover maf. I'd need to do some more reading but apparently it bolts right up?
Old Jan 15, 2016 | 10:07 AM
apex locator
Thanks for the info guys...I got impatient and purchased a 3.5" furookie pipe from TB to filter with a welded on maf flange...pretty smooth inside. I havent installed it yet as I've read that the car wont idle/run correctly with a larger pipe and stock maf sensor. So i'm waiting a bit to pick up a couple other mods before another uprev tune.
I had planned on having everything ready to change to the bigger filter pipe setup while on the dyno.
Old Jan 15, 2016 | 08:33 PM
thE33Z33's Avatar
thE33Z33
Would we need an aftermarket MAF when stepping up to a 3, 3.5, or 4 inch intake?
Old Jan 15, 2016 | 10:14 PM
terrasmak's Avatar
Same thing I have, still tweaking my tune but it's running ok.
Old Jan 15, 2016 | 10:19 PM
Whiskers1996
^^ I can't tell you the amount of time I spent looking for a 3.5'' intake but I always came up empty handed. Tempted to purchase that intake as it looks a lot 'cleaner' than mine and I need a retune anyways.
Old Jan 16, 2016 | 12:50 PM
terrasmak's Avatar
Seems to be 3 available
Furookie
Z1 race
Limp Mode Tuning
Old Jan 16, 2016 | 01:23 PM
Whiskers1996
Furookie
Z1 race
Limp Mode Tuning
Either i'm blind or I just never see those intakes being mentioned much on this forum .
Old Jan 16, 2016 | 05:53 PM
terrasmak's Avatar
Furookie is popular with the G35 crowd, I don't think they really marketed it much to the 350z guys. Z1 just made their race intake not long ago and hasn't marketed it much on our site even though they are a sponsor https://www.z1motorsports.com/air-in...on-p-8453.html . Then finally the Limp Mode Tuning intake is very new and they are not forum sponsors, and no one has reviewed the product on here.
Old Jan 18, 2016 | 08:42 AM
thE33Z33's Avatar
thE33Z33
Kind of like the $100 option from Jegs. Not a pretty system but I imagine it should be just as effective
Cux350z
Intake
Dec 11, 2015 03:34 AM
Whiskers1996
South East Marketplace
Dec 1, 2015 09:13 PM
kyle.ehinger
Dec 1, 2015 03:17 PM
aXxICExXa
Intake
Nov 18, 2015 09:01 AM
indyn
Nov 17, 2015 02:55 PM
