Need help with header installation!
Old Feb 17, 2004 | 02:19 PM
TheLza23's Avatar
TheLza23
Default Need help with header installation!
I just got the stillen headers and was lazy to install it myself so I decided to take it a shop to do it but they all wanted around $300-$400. So I think I'm gonna do it myself and was wondering if anyone had done the headers themselves and can tell me if I'm gonna run into anything unexpected or is it pretty basic.
Old Feb 17, 2004 | 02:33 PM
D@ActiveTuning's Avatar
D@ActiveTuning
It doesn't look like it would be the easiest thing just by looking at the engine compartment.
Old Feb 17, 2004 | 03:20 PM
pimp1911's Avatar
pimp1911
You will be doubting your whole existance as a human being if you do it yourself. I hope you have a lift.
Old Feb 17, 2004 | 03:22 PM
Shocka's Avatar
Shocka
It all depends on your mechnical skills and your tools.
I installed the Xerd headers and there are some bolts that are a real pain in the butt to remove and put on. Most people that have installed headers had to remove the radiator plumbing on the passenger side to get more room to get to the bolts. Although I did not take the plumbing off, I made myself a customized wrench to get to the bolts.
In my opinion, there is nothing that is extraordinary about the job, but there is not much room to work. You will need to be patient and have a good assortment of tools.
I believe it took me about 14 hours to remove and install my headers and complete exhaust system, of that I would say the headers were about 9 to 10 hours.
Old Feb 17, 2004 | 03:32 PM
mofoz's Avatar
mofoz
$300 for the install is decent, and they probably can knock out the install in 1/4 amount of the time. You definetly need a lift if you're considering doing it your self.
Old Feb 17, 2004 | 03:56 PM
FLY BY Z's Avatar
FLY BY Z
Shocka, can you describe the sound of your car or better yet, post a clip? I have the XERDs and am getting the NISMO exhaust in place of this custom. How does it sound regarding raspyness, volume, etc? Thanks!!
Old Feb 17, 2004 | 04:20 PM
Buff's Avatar
Buff
I'd be payin the $300-400 for the install. Unfortunately I don't know of any decent shops in my area so I'm on my own. As for the Stillen model I don't know much about them. I've been able to find installs for the Nismo & Crawfords.
http://www.350zforum.com/tech/NISMOR...neheaders.aspx
http://www.zchickz.com/header1.htm
http://www.crawfordzcar.com/
A lift will make your life a lot easier, but it can be done without it.
Zzzya & Exploder both have experiance & will probably be willing to answer direct questions that you may have. I will be doing an install on 3/6 with Peptidbond & will be posting detailed instructuions if you want to wait.
Best of Luck to you!!
Old Feb 17, 2004 | 05:29 PM
Shocka's Avatar
Shocka
FLY BY Z,
The sound at idle is almost as quiet as stock, of course at about 2000 rpm and up it gets quite a bit louder. There is just a little bit of raspy-ness at about 3000 rpm on deceleration. At high rpms it is loud enough that I don't like revving it to many times to scare the neighbors.
I will try to get you a clip.
Old Feb 17, 2004 | 06:28 PM
FLY BY Z's Avatar
FLY BY Z
Cool. So acceleration is smooth and raspless?
Old Feb 17, 2004 | 07:21 PM
Shocka's Avatar
Shocka
FLY BY Z
I have a sound clip for you, I think it will not come through as it is about 6 MB. I think I will need to get it hosted by someone.
There is an odd clicking sound in the clip, something to do with the camera......but you will get the idea.
Old Feb 17, 2004 | 07:31 PM
FLY BY Z's Avatar
FLY BY Z
Check PM
Old Feb 17, 2004 | 08:02 PM
FLY BY Z's Avatar
FLY BY Z
NISMO Exhaust/Test Pipes - Right Click, Save As Please!!!!
Old Feb 19, 2004 | 06:44 PM
alex30327's Avatar
alex30327
Default Re: Need help with header installation!
Its a complete pain in the **** if you are going to do it at home! I installed mine myself and it took me 15 hours, with jack stands and some decent tools. It is well worth it to have a shop do it. A shop should be able to do it in ~4-5 hours with a lift and the right tools. Several of the bolts are very hard to reach which makes it very easy to strip a bolt. I stripped two of them when I did my install and it was a complete nightmare.
Extreme Dimensions
Southern California
Sep 24, 2015 03:35 PM
