SES Light after Kinetix Install
Old May 7, 2004 | 12:35 PM
xlacrosse's Avatar
xlacrosse
Default SES Light after Kinetix Install
Hey Everyone Im getting a SEL light so i went to autozone and got the code pulled
its states the following
p0441
Evaporative Emission Control System Incorrect Purge Flow
What the hell does this mean??!
Old May 7, 2004 | 02:32 PM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
you forgot to plug something back in..cheak the sensors near the throttle body.
Old May 7, 2004 | 05:41 PM
spdu4ia's Avatar
spdu4ia
i got the same thing and it was my MAF sensor not plugged in all the way
Old May 11, 2004 | 12:07 PM
ChrisMCagle's Avatar
ChrisMCagle
Check my instructions on the install. Most likely you have a plugged fitting on the new plenum. That's what happened to me. It was the vacuum hose connection that was plugged with the glue they used to hold it in.
http://www.350zfreak.com/plenum.htm
-Chris
Old May 11, 2004 | 02:22 PM
xlacrosse's Avatar
xlacrosse
your 100% correct dude...i already found this a few days ago.... hole was completly blocked
Old May 6, 2010 | 10:41 AM
akks350z's Avatar
akks350z
my buddy has same exact code 0441 and has ssv manifold installed then code came....which hose was blocked xlacrosse? the two on the left side of manifold are not blocked i stuck a pick tool all the way in to make sure but i havent check the rear since its hard to get to...
Old May 6, 2010 | 11:28 AM
akks350z's Avatar
akks350z
nm fixed...the installer who put on manifold pinched the hose that goes under manifold towards the back and put them on backwards
loudtoyz
Apr 6, 2023 04:52 AM
Uriyo_
Sep 8, 2021 08:46 AM
samansharif
Sep 25, 2015 12:31 PM
