Kinetix V4 Installed... check engine light???
Old Jul 6, 2004 | 12:37 AM
Dth288's Avatar
Dth288
Default Kinetix V4 Installed... check engine light???
I Receive my V4 plenum on friday (07/02).. I installed it yesterday (sunday)..
Install was pretty easy, i had no probelms besides the 4 bolts of the throttle body which put up a good fight.
After the installation, as soon as i turned on the car the "check engine soon" light came on. Does anyone have any idea as to why this happened? I havent heard of anybody that has had this problem with the plenum so i am assuming it might have been during the installation that something happened. The questions is, WHAT?? what are the possibilities?
After driving it. I did feel the car pulling a lot harder , i've even put a couple of hundred miles on the car like this and everything seems to be fine.
well if anybody has any ideas, suggestions, guess' or anything it would be greatly appreciated. Thanks!
David,
Old Jul 6, 2004 | 12:44 AM
Dth288's Avatar
Dth288
Oh and i havent reseted the ecu to see if it still comes on after that. I'll be trying that soon.
Also, i put test pipes on the car on thursday. I put them on, went home after a 45 min. drive and didnt drive the car again until after the plenum installation. The light didnt come on but is it possibly for it to come on days after?
just wondering...
Old Jul 6, 2004 | 05:32 AM
redline350ZZ's Avatar
redline350ZZ
when I put my intake on the CEL came on for about a day but went away after that.... I would give it a couple of days....
Old Jul 6, 2004 | 05:51 AM
Loco350Z's Avatar
Loco350Z
I would unhook your battery and then wait some time before you hook it back up. Not sure if this will help but thats what i did and it worked.
Old Jul 6, 2004 | 05:52 AM
Loco350Z's Avatar
Loco350Z
Make sure all your hoses are on tight and all the way on as well. the one behind the throttle body is a beotch to get back on
Old Jul 6, 2004 | 06:59 AM
manofsteele2003's Avatar
manofsteele2003
From what I hear, I would take it off and put the stock one back on before it leaves you stranded somewhere. Kenetix is starting to get a bad rep around here.
Old Jul 6, 2004 | 07:11 AM
ares's Avatar
ares
Veteran
tighten everything, give it 3-4 days. if its still off, reinstall the plenum. if its still on... go back to cats. if its STILL on.... come back and ask again.
I assume your idle is steady though? go over it real well for cracks just to be sure.
Old Jul 6, 2004 | 07:57 AM
protocav's Avatar
protocav
it is definitely from the test pipes. they give a check engine light, since there is no cat. you can buy a black box which simulates the O2 sensors. search this site, it's here somewhere.
i installed the black box for a friend, and the CEL went away.
Old Jul 6, 2004 | 02:24 PM
Bahraini350Z's Avatar
Bahraini350Z
But I have fixed test pipes with the sensors on and no CEL shown!
Old Jul 6, 2004 | 03:23 PM
zachcrosen's Avatar
zachcrosen
I have test pipes and ne CEL either. I will be installting my new V4 plenum soon and I hope I dont get a CEL from the install.
Old Jul 6, 2004 | 04:31 PM
Dth288's Avatar
Dth288
Thanks for the info!! i just got home, I will be reseting the ECU and we'll see what happens...
Oh! and my idle is fine, its pretty steady..
well i'll keep you guys posted if anything changes!
Old Jul 6, 2004 | 06:31 PM
Dth288's Avatar
Dth288
Well i reseted the ecu. I disconnected the negative terminal in the battery for about 10min. when i turned the car back on, the "check engine" light wasnt on anymore. i drove around for about 15 min. and the light didnt come on. so far so good but hopefully it'll stay that way.
If it stays this way, i will be going to the track (1/8 ml) on thursday to see what i gained from switching the high flow cats to test pipes and adding the plenum......
silverbullet_Z
NA Builds
24
Nov 14, 2015 02:52 AM
jun14scr
May 26, 2004 04:56 PM
xlacrosse
Apr 30, 2004 08:31 PM
isalvus
Mar 29, 2004 02:47 AM
