Injen CAI
Old Nov 9, 2004 | 10:15 PM
xchriz012x's Avatar
xchriz012x
Default Injen CAI
i just bought a CAI from one of the members on this forum. he didn't have the instruction on installing it.
could one of you people with injen CAI be kind and post the instruction?
thankx
Old Nov 10, 2004 | 02:31 AM
ttsupra94's Avatar
ttsupra94
I dont know if i still have my instructions. It is fairly straight forward though. The only difficult part was getting the plastic piece out where the tube runs through for the full intake setup. You should be able to see all the bolts you need to remove to get off the stock airbox, intake tube and stuff. Detach both of those from the MAF (black thing on the intake with wires attached) and lay the MAF on top of the engine block. There is also a tube you will have to disconnect that connects the intake tube to the back of the engine block, just disconnect the end from the intake pipe. If you are running it short ram, i dont think you need to take out that plastic piece where the hole is in front of the stock airbox. You have to be careful removing the screws to put on the injen heat shield and it is a little difficult to reach. Pretty much the reverse setup for install.
Come to think of it, i'm pretty sure there is an install guide on here with instructions and pictures from a member. Try searching for "injen" and "install", stuff like that. I was just trying to give you the basic idea of the process that i remember from installing mine.
Old Nov 10, 2004 | 06:48 AM
xchriz012x's Avatar
xchriz012x
thanks for your reply and help.
i didn't find anything on installing it.
they were all just removing the bumper and what not.
i'll just try to do it by removing the stock air box.
Old Nov 10, 2004 | 07:02 AM
Street Visionz, Inc.'s Avatar
yeah it's not all that hard, just make sure you tighten all clamps and bolts and make sure nothing's rubbing against anything. Should be pretty straightforward, removing the front bumper helps a lot but is not necessary.
Old Nov 10, 2004 | 07:08 AM
ttsupra94's Avatar
ttsupra94
Yeah, i agree with above. I didn't remove the front bumper, i did remove one or two fasteners so i could move it a little but that was it, just have to work the thing out.
The install would have been incredibly easy for me but when i was trying to get the bolt out of the stock heat shield, the head got stripped (guess it was on too tight from the factory). So I ended up having to take it to the dealer and get them to get that bolt out somehow since I only had very basic tools at home. With no problems, this shouldn't take you long. I really could have sworn there was some kind of write up on this but i guess i was wrong. Good luck man. I'm sure if you do run into any problems, you can ask questions here and are likely to get the answers that you need. There are quite a few people on here with this CAI and many of them installed it themselves.
Old Nov 10, 2004 | 07:13 AM
ttsupra94's Avatar
ttsupra94
ah ha, i found the link. This is what i looked at when installing mine, the instructions that came with it helped cause they had a couple pictures. But this link should be all you need man
https://my350z.com/forum/showthread....en+cai+install
Old Nov 10, 2004 | 08:48 AM
jovasi's Avatar
jovasi
Here you go
www.overboost.com/story.asp?id=1085
Old Nov 10, 2004 | 05:28 PM
xchriz012x's Avatar
xchriz012x
thanks for the links guyz.
i'm gonna install it tomorrow.
do i need to remove the splash guard to place the heat shield?
Old Nov 11, 2004 | 02:49 AM
jovasi's Avatar
jovasi
If you're refering to the splash guard underneath the car, no. You can reach the heat shield from the engine bay. Good luck with the install.
Old Nov 11, 2004 | 08:50 AM
xchriz012x's Avatar
xchriz012x
does this piece come with all the injen intake systems?
or just specifc ones? cuz i have the similar piece without the little piece where the hose attaches.
bought a used one off of someone and got the other piece instead.
Old Nov 11, 2004 | 08:54 AM
ttsupra94's Avatar
ttsupra94
As far as i know it comes with all of them. that attaches to the MAF and then there is a 15"(i think) thin hose that connects on that tube to an outlet on the side of the engine bay. Are you having a problem or just curious if it came with all intakes?
Old Nov 11, 2004 | 09:04 AM
xchriz012x's Avatar
xchriz012x
here's a picture of what i have.
just curious, cuz looking at other injen intakes...the piece looked different.
Old Nov 11, 2004 | 09:20 AM
ttsupra94's Avatar
ttsupra94
Yeah, Mine was different I guess, i had the red/polished kit. I had all that you see there except i had the metal piece that had the piece where the hose attaches and then I had a thin long hose that was red that connect to the metal peice and to the firewall. the piece hanging off the red pipe you have connects to the stock tube that connects to the rear of the engine block i believe. I'm not sure what to tell you though.
Old Nov 11, 2004 | 09:23 AM
ttsupra94's Avatar
ttsupra94
I'd try and take some pictures and show you mine setup on the car but i'm at work. If you haven't finished by tomorrow and still need help, i will be at home and can take some pictures and try and help you out. You should still be using the exact same setup as described in those threads you just dont have that thin tube that connects the metal piece to the firewall. I guess you got one of the very early ones, i dont really know.
Old Nov 11, 2004 | 11:51 AM
jovasi's Avatar
jovasi
It looks like instead of attaching the hose to the small piece that attaches to the MAF like we have, the hose will attach to the main tube (see the nipple sticking out of the piece that says Injen) on yours.
Old Nov 11, 2004 | 11:58 AM
ttsupra94's Avatar
ttsupra94
i thought the hose that attaches to the main tube is the tube that attaches to the rear of the engine block...... thinking back though now, i really can't remember if we have a tube that comes off the polished pipe. I haven't looked at that in a while so i can't remember.
Old Nov 11, 2004 | 11:59 AM
Gary King's Avatar
Gary King
There is a decent write up of a Injen Cold Air Intake install with pics on this website www.gridesinc.com
Go to the showroom button
Old Nov 11, 2004 | 01:38 PM
xchriz012x's Avatar
xchriz012x
just got done installing this intake.
took me 4 hrs!!!! i swear i feel like my car is the defected one.
nothing worked out. had to struggle getting the front bumper removed. after installing it, i have few screws left...check engine light lit...and the strut bar won't fit perfectly...leaving me with 3 bolts that won't go in.
what do i do?
is the check engine light normal??
Old Nov 12, 2004 | 08:13 AM
jmckuhen's Avatar
jmckuhen
what do i do?
Did you disconnect the negetive terminal on your battery before installation? If not you probably just need to reset your ECU. Disconnect the negative terminal of your battery and let it sit for a while (like 20-30mins). Then reconnect the battery terminal and your ready to go.
Old Nov 12, 2004 | 12:21 PM
xchriz012x's Avatar
xchriz012x
the last thing i did before starting the car up was connecting the battery.
but i'll give it a shot again.
hope it works.
