front adj. control arm recommendations ?
Old Jul 30, 2005 | 09:47 AM
unit5alive's Avatar
unit5alive
Default front adj. control arm recommendations ?
Ive got an 03 track with 3700 miles, front tires are feathered , anybody find any control arms they like, just trying to knock the neg. camber back to get the feathering issue fixed, did a search didnt find anything ,Craig
Old Jul 31, 2005 | 03:08 PM
MyNismoRoadster's Avatar
MyNismoRoadster
its not a camber issue, its a toe out issue, read this thread.
https://my350z.com/forum/maintenance-and-repair/15758-tire-feathering-fyi.html
Old Jul 31, 2005 | 05:30 PM
unit5alive's Avatar
unit5alive
If it is a toe problem why are all these people filing a class action suit after have there cars aligned at the dealer? only to have the same feathering problem, the only ones that I read that have fixed there problem have added arms to reduce the camber under 1 degree.
Old Jul 31, 2005 | 10:15 PM
MyNismoRoadster
camber doesnt cause feathering, improper toe does, toe in will cause outer tire wear, toe out will cause inside tire wear, its similar to camber but camber wears out on one side or the other of the tire but does not feather. in general sports cars all are supposed to have camber, thats why they handle soo beautifully, old Z32 300zx has 1.5 deg camber from the factory but no one complains about it....i dunno why all the 350z ppl are....300zx did camber wear their tires but they would cross rotate them but they did not feather.
Old Aug 1, 2005 | 04:36 PM
bwilliams's Avatar
bwilliams
Unit,
you may want to research a little deaper.
The car is sensitive about frt toe setting.
My wife's SUV would hug the road too, if I aligned it like a Z. It would also wear tires quicker.
Yes, many people continue to have problems after multiple dealer alignments. Read that sentence carefully and spend the $50 to have a good independent shop do a precise alignment. The car will hold the alignment you give it.
After 37k miles of dealer induced feathering and three sets of tires, I had my independent shop put an accurate alignment on my car. For the last 20k miles, no feathering!
It's a shame more people don't realize there is NOTHING special about the dealership. The dealers are the general practitioners of the automotive world. If you have a front end issue...take it to a front end specialist...duh! I think the tires play a very small role in this problem...it's mostly front geometry.
Please forgive the attitude. I've thought about this problem for 58k miles and wish more owners would open their minds that the solutions (yes, more than one) are available and don't necessarily involve the dealerships.
Old Aug 1, 2005 | 05:05 PM
JS04's Avatar
JS04
So if its a front toe alignment issue what is the measurement for the alignment to stop the feathering.
Old Aug 1, 2005 | 07:04 PM
MyNismoRoadster
if you want to stop all feathering, i would think the toe would have to be set at "0" toe.
Old Aug 3, 2005 | 03:10 PM
bwilliams's Avatar
bwilliams
MNR, In theory, you are right. However, you probably would not like the handling characteristics. A little toe is good.
JS04, I set mine at the latest factory spec (mid point), and I still have good handling with no feathering. I don't recall the number. I'll come back later with it.
Old Aug 3, 2005 | 06:57 PM
MyNismoRoadster
Correct, a little toe aids in stability while exiting the turns fast.
Old Aug 4, 2005 | 03:35 AM
unit5alive's Avatar
unit5alive
Well , anyone have any control arm recommondations, this car is a toy for my wife to drive,mainly goes to the dairy queen, Im going to set the toe in at min spec. and reduce the neg camber to around 3/4 degree ,handling is 2nd to tire wear on a car that was bought as a toy. (not for corner carving )
Old Aug 5, 2005 | 08:52 PM
MyNismoRoadster
any particular price range? as there is a lot makers that make pretty the same thing.
You can also check out our suspension section http://performancenissanparts.com/ca...02_153_261_401
Old Aug 7, 2005 | 06:20 AM
bwilliams's Avatar
bwilliams
MyNismoRoadster,
Do you represent a vendor while posting on this site? If so, don't you have to identify yourself as a vendor's rep?
Old Aug 8, 2005 | 08:37 PM
MyNismoRoadster
MyNismoRoadster,
i work for performance nissan, and why do i have to mark myself as a vendor for? we have a bunch of our guys in here promoting anyways, im just hanging out on my spare time off work.
Old Aug 8, 2005 | 09:14 PM
accordfreak's Avatar
accordfreak
anybody have the latest factory spec to correct the toe problem and have good handling?
Old Aug 10, 2005 | 08:04 PM
bwilliams's Avatar
bwilliams
To Performance Nissan Rep,
Transparency? Forthright?
I, for one, like to know if I'm reading the words of a vendor. I don't know if you have to mark yourself. I would hope that Performance Nissan employees that are plugging the company would feel an obligation to the readers on this site to clearly disclose and identify yourself as such.
Old Aug 10, 2005 | 11:44 PM
MyNismoRoadster
How does it matter if i work for them or not, i been on this forum before i worked for them and i dont feel obligated to disclose my self as being a employee of a vendor on this forum especially when we already have a few helpful and knowledgable Performance Nissan staff on this board daily, i dont think it matters, as long as my info is passed on to be helpful to someone thats all that matters. I chose to just be like any other member. This is the only forum i been to out of the 6 other forums i visit daily that has a problem with this. What you are basically saying is that if it comes from a vendor will make a difference to you as opposed to a knowlegable regular member? I personally dont think it matters. Just my 2 cents on this.
Old Aug 13, 2005 | 02:40 AM
bwilliams's Avatar
bwilliams
The nominal front alignment requirement, as of Feb 2005,
total toe= .1 degrees
The other geometry, you can't do anything about without aftermarket suspension.
For aftermarket suspension, shop around and compare...there are many sources for these parts. Some sources market openly, some covertly, some not at all. Don't confuse marketing effort with quality.
Old Aug 13, 2005 | 06:00 PM
KShep's Avatar
KShep
Cusco offers an reasonably priced set of adjustable upper A-arms...350EVO has a more expensive offering.
http://www.z1auto.com/prodmore.asp?m...ng&prodid=1288
http://www.350evo.com/catalog/produc...7b99660a54f029
hth
Old Aug 14, 2005 | 02:06 AM
MyNismoRoadster
hth
2nded, Cusco is offering a reasonable price unit, its cheaper then most of the ones i seen but effective, only gripe i have with the sliding type is that they tend to slip sometimes during hard cornering.
Obadabot
Jun 18, 2023 11:31 PM
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
