help whats wrong??!?!?
Old Nov 6, 2005 | 07:08 PM
babyz's Avatar
babyz
Unhappy help whats wrong??!?!?
i was driven and i got a flat! on my rear tires i have 19 axis all around w/ a drop, and ddidnt have my spare, so i borrrowed my freinds spare from his altima, than i was goin home, which was a good 22 mile drive all of a sudden my cluthc or some thin messes up and i dont know wahts wrong, i jus replace my tranny and clutch like 10k miles has some one ever experience this problem before.
my car you dont have to hold the clutch down, you can jus pop it in gear but it will not move, but gas will jus raise the rpms.... \
please let me know i think its the differentials for my rear tire????..........
Old Nov 6, 2005 | 07:17 PM
If there is a quarter inch difference in the height of the rear right and rear left tires, TCS will shut down the car. You have to pull to the side of the road, wait a minute then restart the car. At about 60 mph, the car will shut down again. It happened to me when a tire shop put the wrong wheels and wrong tires on the wrong axles.
Old Nov 6, 2005 | 08:22 PM
babyz's Avatar
babyz
man ya i knnow but now my car is chillin in my garage, and its not movin, like all its doin is jus pops in gear and revs thats it, you think if i fix my tires and take it to nissan warantiee? will help me?
Old Nov 7, 2005 | 05:28 AM
Excellent idea. Put the correct wheels and tires on the car, then take it to the dealer. I haven't the faintest idea what the problem is. Unfortunately if the car doesn’t run, you may have to have it towed.
Old Nov 7, 2005 | 06:24 AM
chimmike's Avatar
chimmike
how about a better description of what's going on? any odd sounds? etc? what happens when you push the clutch pedal in?
Have you checked the driveshaft under the car?
Old Nov 7, 2005 | 08:05 AM
babyz's Avatar
babyz
well there is no odd sound its jus like you turn onthe car, everything is normal you dont even have to push the clutch down to pop it 1-6 or reverese it jus goes in smoothly and when you try to acclerate it jus revs, the vdc, tcs, brake, slip sighns are showing, when i was driving, my car started loosing control, from one wheel, when i took the exit, my right wheel rear (that had the spare) it kept like making a weird sound likea grinding sound than the car finali stop moving. anyone ever had this problem
-nah i have not cheacked anythin under the car yet-
some one any ideas..............
Old Nov 7, 2005 | 02:34 PM
Machupo's Avatar
Machupo
it sounds like your clutch is stuck in, but i'd start with putting the correct tire on the car and towing it to a dealer...
might want to invest in roadside assistance next time... driving on the wrong tire was your first mistake and it might be better for your car in the long run to just have someone qualified fix it...
Old Nov 7, 2005 | 03:04 PM
babyz's Avatar
babyz
ya man thx alot well see whats up ill find out in a couple days you think after i slap my rims back on waranatiee will cover it?
Obadabot
Jun 18, 2023 11:31 PM
derekinthez
South East
Sep 28, 2015 06:35 PM
