Tire FEATHERING: FYI
Originally posted by Boomer
I urge you correct it now, leaving it for longer just makes it harder to minimize the wear.
I've found a solution to my wear problem. My current tires are Bridgestone S03s and I've had the TSB, alignment, another alignment and still have the feathering slowly returning.
Yesterday my son and I took the Z to the track and ran autocross. 6 runs apiece and I don't care about the tires. The course takes care of the feathering quite nicely.
Just an update from back then on the tire problem. Nissan replaced the front tires with Michelin Pilot Sports. I had to pay $100/tire, which was fine. It made all the difference. I've logged 10K miles on these tires and it's been great. I went with Michelin HX or something or other in the back. A little less expensive. If anyone reads this and knows of a tire that is high performance with more mileage, let me know... rxbethany@msn.com
Lucky you I'm about to take my car in for new tires. Sucks that they will be the same piece of crap on it now, but this is the 4th documented time in for the problem. I tried to get my dealer to go with the Pilot Sports, but he refused. He owns a 350 too...what a dick...
Originally posted by cal_z
what kind of luck are you guys having in getting the tires replaced after the 12000 ml mark?
On a side bar, I drove the car to Columbia SC from Atlanta today and got 27.3 miles per gallon.
They tried the TSB at 9000 - didn't work.
They redid the alignment at the same time as the new tires, to the "roving Japanese Engineer" spec. I'm on 19,500 now, but it's too early to see if the feathering is coming back. It hasn't yet, anyway.
Had to pay a visit to Autoway Nissan in Clearwater today on a related issue (wheel damage and repair done during the last tire change) and here is what little info regarding tire feathering I was able to glean from the Service Manager. By the way, in spite of everything I have said about these guys, they still have the best service department in the area. Anyway, with regard to my car, while we were looking at the wheels , the Service Manager, the same guy who claimed I had no feathering 1 month ago, looked at the tire and, with no provocation from me, announced that I had feathering on the outside edge. This is what I have been trying to tell him for two months. He is as stumped about the cause as I am. He also showed me his latest feathered RE040 collection. He said he just recently replaced 5 more sets, if I understood him correctly. He said multiply that by the number of Nissan Dealers and that is alot of cars. He then showed me a 350 that had just come in for feathering. It was an '03. He wasn't sure about the mileage but thought it was close to 15K. He said Nissan denied the customer a new set of tires stating that "they are only a 20k tire". And these were bad. Way beyond heel and toe. The inside tread blocks were just completely cupped beyond all recognition. I can't believe the owner waited that long to come in. I also asked the SM if he had any knowledge of a suspension change in '04 and he said he did not. In my mind all of this does not bode well for that supposed forthcoming tire fix. I am really starting to believe that Nissan is just going to blow this whole thing off. I then told him that I had filed the motor vehicle defect form and asked him if he had a problem with the final repair attempt being done there. He said he did not. I'd like to thank Steve at Autoway for taking the time to speak to me in a friendly, open and honest manner.
Originally posted by negeo
has a formal complaint been filed yet? this feathering problem has affected so many of us. i for one will sign on.
Hi Mr.
I'm sending you an update regarding our conversation last week on the 2004 350z. I had a chance to speak with our internal 350Z specialist to pick his brain on the wheel alignment issue for the 350z. And I was advised that revised suspension specifications, including European tuned shocks, springs, and stabilizer bars have been installed in the 2004 350z so the 2004 350z should not exhibit the same type of suspension concerns w/ the 2003 350z's.
I was also advised that Nissan has addressed all concerns regarding the suspension settings and based on a Nationwide consumer response vehicle suspension is overall performing to Nissan's and Consumer's expectations.
I hope the above information helps, in making your purchase decision and thanks for contacting Nissan Consumer Affairs.
Cordially,
Jean D Wilson
Cordially,
Jean D Wilson
In light of this I offer you my interpretation of the 2003-2004 350Z Accelerated Repurchase Program or How to Drive a 350Z for Two years For Free. Nissan has a State Certified Arbitration Program in most States. You don't need an attorney and even if you get one he or she may be forced to submit to the same arbitration program. Of course, you can also file under Federal Law in which case you will need an attorney. In any case I am not giving any legal advice here so much as outlining the vehicle preparation neccessary to take advantage of the Repurchase Program that Nissan has forced many of us to pursue. Laws vary by State and in this example I am using the three (3) strike rule plus a final repair attempt which is typical. Save all work orders and take meticulous notes of every event and conversation related to the issue. If you take the vehicle in and they do nothing, get a work order that says that they did nothing.
If you own an affected vehicle you should not delay in getting it in for service. Don't wait until the front tires are cupped beyond all recognition. Take it in at the first sign of heel and toe wear. This pattern became apparent at just over 3,000 miles on my vehicle. They will undoubtedly apply the latest TSB. Strike one. Perhaps they will even give you new tires if you ask but you are better off not asking for new tires. If they replace the tires you are looking at 3,000-5,000 miles before you can re-assert your claim. If they don't replace them you can take it back immediately. If you get it in early they are less likely to replace the tires.
Assuming that they only do the rotation the first time, take it back in again in about 30 days on the basis that the tires are still cupped and noisey and you want new tires. They may re-apply the TSB, replace the tires or do nothing. Strike 2. In any case get a copy of the work order.
Let's assume that you got new tires during the second repair attempt. That would probably be typical. You may have as little as 5K on the car at this point. Now you need to do some driving. You've got to put enough miles on the car as fast as possible and take it right back to the same Dealer that replaced the tires last time as soon as the heel and toe pattern starts to appear. He is going to be very reluctant to replace the tires again at that point. Nissan is going to be very reluctant to replace the tires again if at all. They may do another alignment. In any case, it's Strike 3 for Nissan.
If the tires were not replaced at the third repair attempt then you can send your certified vehicle defect notification to Nissan and go right to the final repair attempt. Otherwise you've got some more driving to do. At the final repair attempt, Nissan, based on what I have seen, will do nothing more than check the alignment and replace the tires. Don't accept snow tires like the Pilot Sport A/S or other ultra-hard low performance tires that will just mask the problem and delay your case. Insist upon the soft high performance tires that the car was designed for. Once the final repair attempt is completed you've got some more driving to do. Rack up enough miles until the feathering begins again. Take a road trip out West or East, as the case may be. That should do it. That's Strike 4 and you can now go directly to arbitration where you will easily prevail based upon Nissan's total lack of a case. But before you do that send Nissan another certified letter offering to settle the case. They don't want a retitled "lemon" on their hands. They don't want to pay for legal fees and other expenses. It is in their best interest to settle. Offer to settle for a complete repurchase with no offset for use or, at the very least, the offset limited to the mileage at which the problem was first reported. If they don't settle, go after them with a vengence. Enter the certified Arbitration Program if it exists and file a Federal Suit. Now they are looking at very expensive legal fees and may reconsider your settlement offer. Either way it's going to cost you nothing and you will win.
Three weeks ago, after listening to the tire noise grow louder and louder, I decided to call Nissan Consumer Affairs and file a complaint. My '03 Touring with 7,500 miles was suffering from the grease streak problem, squeaking brakes and annoying tire roar. The rep. took down my info. and tried to tell me that he hadn't receive many complaints related to mine(total BS!). I asked him if he was aware of the TSB's that had been issued to correct my problems and he said he'd check into it, whatever that means. Either way, I didn't really care what he had to say, I just wanted someone to document my issues.
I then contacted my dealership and explained to them that I was due for my 7,500 service and that I'd also need a few other services provided. I did the night drop thing and included a letter detailing my issues and the related TSB #'s. I also mentioned in the letter that I had contacted Consumer Affairs and gave them my case number. Later that day, the dealership called and said that they had resurfaced my front rotars, which would eliminate the squeal. They plugged something in the door to ensure that I'd have no more grease streaks. And then the best thing, they said that they would replace my front tires because of the noise and uneven wear at no cost to me. The catch..."Unfortunately, the tires are on back order,... blah, blah, blah." Anyhow, they arrived a couple of days ago and were put on yesterday. I had them print out a spec sheet for me listing the before and after settings for my camber, caster and toe. A couple of the settings were really off originally. My new toe settings are at .04 on both the LF and RF and .02 in the rear. My camber is at -1.0 LF and -0.7 RF. Do these numbers sound about right? And they ended up putting back on the same Bridgestone Potenza's RE040's. I asked him "Don't you think I'll be back in here in another 8,000 wanting new tires" and he said, "No, because we adjusted the pitch." What the heck does that mean? I also asked him about installing a new suspension and he said that wasn't necessary because now all of the settings are correct. Didn't know enough about "pitch" to argue with him, so I just drove home. Wow, what a difference new fronts make. I didn't have to cut my radio up at all to drown out the noise. It's so.....normal, now. Unfortunately I think it's going to be short lived. However, I'm going to stay optimistic.
My dealership treated me with a lot of respect and really appreciated my letter documenting all of my concerns. They really deserve some recognition for a great job with no hassles. My rep from Consumer Affairs on the otherhand, sucked the big one. I left several meesages for him and he never returned any of them.
So a couple of questions: do my settings sound accurate and what does pitch have to do with tire wear?
Thanks!
Thanks!
Originally posted by chudson1984
[So a couple of questions: do my settings sound accurate and what does pitch have to do with tire wear?
Thanks! [/B]
Thanks! [/B]
side note: how do you like the TSB for the grease streak. any problems with the door, window or wind noise now? I need mine done but i have heard some pretty bad horror stories about problems afterward. your input would be appreciated.
Originally posted by supirio
Year/Trim: 2003 Touring
Manufactured: 11/03
Noticed problem: 4,900 miles
Tires swapped at: 6,700 miles
Car drives like new again with the tires swapped, I then felt the now outside tread and severe cupping was felt all the way around the two front tires. Dealership stated they would replace the tires if/when it happens again as long as its under 12,000 miles. Does this mean after 12,000 they won't do anything for me?
Manufactured: 11/03
I had my tires swapped at 9000 miles and then replaced at 13000
by NNA.
One piece of advice a guy gave me as a rookie to running a true street car on the track was after a lot of hard runs if you use the brakes a lot was to just change out the fluid. Sure enough, the brake fluid was darker red and ready for a change out. That, and don't put on the parking brake when you park in the pits right after coming off the track!
p.s. If you have the autocross bug check out the Hardbar & 6-point harness I still have in private classifieds - collecting dust now...puts the harness right height (shoulder, not below) and is a 2-bolt installation.
http://homepage.mac.com/stracy01/MOV00012.MPG
Add another one to the list. I just had my 03 in for the feathering.
Same story.
Started 8000 miles.
TSB 8500 miles.
Replaced tires 9500 Miles.
Thats were I am at now.
The service advisor said i had to rotate the tires side to side every 6000 miles. Get an alignment every year. It was a one time fix and the alignment should fix the problem, and there is nothing they can do if the feathering comes back.
We will see. I hope it doesn't.
Same story.
Started 8000 miles.
TSB 8500 miles.
I had a problem with my dealer dickin' me around, called NNA they sent me to another dealer a couple weeks ago. I had my tires replaced yesterday. I asked about alignment and the rep said I did not need it. Today he calls me and says NNA has requested they do another alignment on my car ASAP... The loop is starting again...
I am well over 5 times having my car in and my buddy (that drives a G) just laughs when he follows me into the dealer...Now I have to wait til it comes back to report it a lemon.
Does anyone know if you can file for lemon law after the 12k, 12 month time period if the problem still exsists?
