Nissan Recall on 52,400 350Z's
Old Feb 4, 2009 | 03:07 PM
  #481
SniperHunter's Avatar
SniperHunter
It's free. Warranty doesn't matter. Call up a dealer, give them your VIN and find out if you need it.
Old Mar 26, 2009 | 10:19 PM
  #482
Locoplumbing's Avatar
Locoplumbing
hey guys im new here and i just heard of this recall. about two weeks ago my check engine light came on and i got the code checked and it was the gas cap not sealing rigth or something. can this recall have something to do w/ this problem also the car seems like it stutters or there is like a fuel clog that cuts it off for a mila second in short pauses. wht do u all think?
thanks
-ed
Old Mar 27, 2009 | 06:39 AM
  #483
Road Warrior's Avatar
Road Warrior
ed,
i doubt this is your problem as this recall should have been done on the car...anytime you go in for service they will pull up the vin and do the work. i thought there was another recall or fix for the gas cap problem that you are describing that is not part of this recall. this should also be free of charge.
rw
out
Old Oct 7, 2009 | 02:50 PM
  #484
xsmallpaulx's Avatar
xsmallpaulx
hello i have a 03 track model that is twin turboed. i know that i have a problem with the hose cause everytime i fill up my garage and cabin of the car smells like gas. my question is what kind of stuff can the dealership screw up by doing this repair because my car is twin turboed? i know that i have a returned fuel line and other stuff. i really dont want to take my car in but i know i have to the gas smell is so bad. i just need to know what all they can mess up so i can bring it to their attention before the repair. thanks
Old Oct 7, 2009 | 02:57 PM
  #485
marques1's Avatar
marques1
just wondering is this a new tsb! Just trying to figure out when this thread was made.
Old Oct 7, 2009 | 06:02 PM
  #486
SteveZ's Avatar
SteveZ
Nothing other than maybe nicking the paint on your Brembo calipers (ask me how I know). This is all drop the rear and tank, replace hoses, very labor intensive and also if you have the rear axle click TSB issue this should fix that as they re-lube the splines when re-assembling the rear end.
Your TT has nothing to worry about here other than joy-riding mechs. And to the previous poster, I had this done at least 1-2 years ago, it's been around for awhile.
This has more to do with the evap hoses on top of the tank degrading due to heat and ozone, etc. It has zero to do with the high pressure fuel line or return.
Get it done, the reason this is so widespread is there is a remote chance of leakage or vapors igniting, that would be...unfortunate.
Just buy some touch up paint in case they are careless with your rear calipers Seriously, they're supposed to wrap them in shop towel and tie them out of the way...it's in the detailed instructions.
Old Oct 8, 2009 | 05:43 PM
  #487
vics350's Avatar
vics350
Steve, which dealership did this work for you?
I have an '03 (ordered March of '02) and I fall into the category for this recall. I tried to stay away from doing it but now when I fill up my tank some gas leaks down. If I keep the tank around 3/4" full I have no leak.
I'm worried about doing the recall as I've got an aftermarket exhaust and big brake kit but I can't accept this leak.
Old Oct 8, 2009 | 05:53 PM
  #488
SteveZ's Avatar
SteveZ
re: which dealer pm sent
Btw it almost sounds like you have a leak in the filler neck which is not unheard of, depends on where the leak is. If the breather hoses (or whatever they are called) were leaking it's more a vapor issue when stationary, maybe they'd leak under cornering, IDK.
Old Oct 8, 2009 | 06:06 PM
  #489
SteveZ's Avatar
SteveZ
Neither mod will matter. This is a safety recall, they will do the work. Somewhere out there my original Z (ordered Sept 2002, took delivery in Nov 02) had to get this done, too. I don't want to praise or criticize a particular dealer in public because I think each person's experience depends a lot on how they approach things and their relationship with the dealer SM - I've gotten some excellent treatment, and some less excellent. Thus the PM
Old Oct 13, 2009 | 01:21 PM
  #490
sxr891's Avatar
sxr891
was there a deadline on when you had to take it in by?
how do you know if it has already been done to your 350?
Old Oct 13, 2009 | 02:44 PM
  #491
SteveZ's Avatar
SteveZ
No, it is still active, and you know by your VIN. Roughly speaking, all 2003-2004's. But just call a dealer and give them your VIN, they can tell you in a few minutes.
Go to: http://www-odi.nhtsa.dot.gov/recalls/recallsearch.cfm
and punch in this number:
NHTSA Campaign ID number : 05V555000
using quick search - it will take you right to it.
HTH
Old Dec 1, 2009 | 03:51 PM
  #492
XL0rd123's Avatar
XL0rd123
how long does it usually take for the dealer to do all the work?
Old Dec 1, 2009 | 04:10 PM
  #493
KornerCarver's Avatar
KornerCarver
I can't imagine there are any '03 or '04 Z's out there that have not had this recall work done. I think I had mine fixed in the spring of 2006.
Old Jul 17, 2010 | 04:28 PM
  #494
JJC42482's Avatar
JJC42482
I noticed the recall VIN #s all began with either 3T or 4T. My VIN is 4M, so does that mean my Z isn't part of the recall?
Old Sep 12, 2010 | 06:52 AM
  #495
derekinthez's Avatar
derekinthez
Originally Posted by tonystark
I am starting to wonder about the quality of nissan cars. I am sure that BMW owners don't have these problems.
How much you willing to bet?
Old Oct 2, 2010 | 05:27 AM
  #496
350doc's Avatar
350doc
Originally Posted by JonsilvZ
Since its not mandatory. I guess we are not at high risk of failing. Is there any documented failures? I know there are a # of Zs with high miles.
My UK 350Z fuel filler hose cracked at well over 100,000 miles and around 5 years of age. It was not covered by a European recall and I had to pay several hundred pounds to get it fixed.
Old Nov 7, 2010 | 05:59 PM
  #497
JJC42482's Avatar
JJC42482
I have an '04 Z but my VIN # wasn't included in the recall.
Old Nov 7, 2010 | 06:09 PM
  #498
JJC42482's Avatar
JJC42482
Wrong. It does NOT affect ALL '03 and '04 Z's, only some.
Originally Posted by MustGoFastR
Anybody see this?:
http://www.cars.com/go/news/Story.js...=&aff=national
Affects all '03 and '04 Zs and Gs. When do we get our letters?
Old Apr 5, 2013 | 10:57 AM
  #499
txmad's Avatar
txmad
=( dang
Old Apr 5, 2013 | 11:06 AM
  #500
kcobean's Avatar
kcobean
Originally Posted by txmad
=( dang
Holy Dead Thread Revival!!!!
