Seat Belt Retraction
Old Apr 17, 2006 | 10:56 PM
lakez34's Avatar
lakez34
Default Seat Belt Retraction
I'm having trouble with my driver side seatbelt. It doesn't seem to retract back all the way. I have a feeling it's twisted the opposite direction inside the slot where it retracts because the seatbelt is facing down instead of up like the passenger side. However, I'm not positive if that's always been the case.
Any suggestions on trying to fix this problem?
Old Apr 18, 2006 | 08:54 PM
lakez34's Avatar
lakez34
Any ideas? Sorry to bump my own thread.
Old Apr 20, 2006 | 02:54 PM
sisco534's Avatar
sisco534
Mine is like that too , I have to manually retract it. It has always been like that it is a pain but I am used to it now.
Old Apr 21, 2006 | 10:17 AM
lakez34's Avatar
lakez34
I'm scheduled to have my tires taken care of for feathering this weekend. Hopefully I can have the dealer look into the seat belt issue as well. More than anything, it's annoying, especially when it's hanging w/o properly retracting and I'm going to close the door. I'm afraid it'll slam with the seat belt, and that's never pleasant.
Old Apr 25, 2006 | 04:30 AM
Eazzy's Avatar
Eazzy
Common Prob weather it be Ford or Nissan etc. Pull it all the way out -- If its twisted u;ll see that it is ---If not --Like it was said ,,live with it as I do. Dont buy another one It will do the same thing and set u back a couple 100
Old Apr 25, 2006 | 06:28 PM
mberthia's Avatar
mberthia
Seat belts are warranteed for 10yrs unlimited miles. Federal requirement I beleive plus its stated in the manual. Try to get it fixed. These belts are made by Takata and they used to have a problem with the d-ring collecting gunk and getting more friction. I would think they since fixed that so it may be the retractor spring itself. I'm supprised to see that yours is slow to retract since mine snaps back so fast it marks the trip pieces. I have an 03 so maybe complaints made them change it to a lower spring force. Cant get everyone happy...
Old Apr 27, 2006 | 02:47 PM
lakez34's Avatar
lakez34
So, it seems to have corrected itself. I'm pretty sure it was just twisted. However, I wasn't able to untwist it myself by pulling it all the way out and retracting, or anything else. But, the problem seems to have gone away for now, so oh well. Thanks for the help guys!
Old Jan 20, 2010 | 02:41 PM
Master Shake's Avatar
Master Shake
I am having a problem with my passenger side seat belt. It is stuck in the retracted position and will not move (the driver side works fine). I checked with the dealer and they said only the belt itself is covered (from ripping, tearing, etc), not anything that moves. Basically, they are quoting an estimate of ~$250 to repair the locked seat belt.
I did some basic online searching and could not find anything that states there is a federal law about any kind of seat belt warranty. I also don't see anything related to a seat belt warranty in my owner's manual. Can anyone point me in the right direction?
Old Jan 20, 2010 | 05:03 PM
mberthia's Avatar
mberthia
Check your Nissan Warranty Information booklet in the seat belt section. If you cannot find it you can get it from: http://www.nissanusa.com/apps/techpubs
It says :"This warranty covers any Nissan supplied seat belt or related component, that fails to function properly during normal use within 10 years... etc"
Your dealer is wrong.
Old Jan 22, 2010 | 12:41 PM
Master Shake
Thanks, I think the key is checking in the Nissan Warranty Information booklet, as you mentioned. I was checking the Owner's Manual, under the warranty section.
Plus, I will also try a different dealer...
Old Jan 22, 2010 | 12:54 PM
JCat's Avatar
JCat
Dealer replaced mine.
Old Jan 28, 2010 | 07:11 AM
Z_Youlater's Avatar
Z_Youlater
Correct me if im wrong, isnt it in the booklet said that Safety issues is cover under waranty with Unlimited miles??? Take it to the dealer man. Nissan dealerships...
Old Nov 5, 2013 | 01:33 PM
txmad's Avatar
txmad
YO dude this just started happening to me ..... did you ever get it fixed ?????
Old Nov 5, 2013 | 02:12 PM
Spike100's Avatar
Spike100
Your seatbelt and its mechanisms (the latch and roller mechanism) and the anchor points are covered forever. This is safety equipment that should never fail.
The only exception is an owner who modified the equipment. That is why you should have the dealer perform the repair (actually it is a replacement).
--Spike
Old Nov 6, 2013 | 06:43 AM
txmad's Avatar
txmad
so i can just basically walk to the dealership and get this fixed free of charge ??? whoa ... i tried looking for more info on my manual but no luck yet =(
Old Nov 6, 2013 | 04:04 PM
Spike100's Avatar
Spike100
Yes... But I suggest making a service appointment.
3vilbunny
Jul 18, 2017 05:10 PM
HoBrahYouStink
Jun 24, 2016 10:58 PM
Vigman
Nov 17, 2015 04:34 AM
Fixxxercask
Nov 9, 2015 11:10 AM
