Bad clicking noise when take off and slow down
Heres what I do:
1. lift vehicle
2. remove rear wheels
3. remove cotter pin and huge center nut
4. remove exhaust components that may be in the way of removing the axles
5. I forget if the sway bar needs to be removed, but it will be obvious if it needs to go when removing the axles
6.. remove nuts and bolts that hold the axle to the axle stubs on the differential
7. remove axles [they may be a little tough to slide out, so put the nut back on the tip of the threaded part of the axle, then hammer the axle out with a dead-blow hammer. And PB Blaster helps too]
8. now clean the flange on the axle [flange that mates behind hub bearing] with brake cleaner and a scotch brite if needed
9. Place a generous amount of grease on the now cleaned flange
10. Now put everything back in the reverse order
11. use a new cotter pin
Remember to torque everything to torque specs
I believe that the 38 parts that the TSB is saying that needs to be replaced are the cotter pins, huge center axle nuts, and all the nuts, bolts, and washers that hold the axle to the axle stubs on the differential. I reuse all of these, minus the cotter pin which i replace, and haven't had any repercussions because of it.
