passenger windows does NOT work. please help
Old Aug 10, 2006 | 09:24 PM
zzz350zzz's Avatar
zzz350zzz
Default passenger windows does NOT work. please help
hi,
my passenger window does not work. I can roll the windows down fine, but it does not go back up. Therefore, I do not think the motor is busted.
Could it be the switch is bad? thanks
Old Aug 11, 2006 | 04:18 AM
VandyZ's Avatar
VandyZ
yeah it is the motor Mine did the same thing.
One way to get it to go back up is to have car on, open door, hold window switch up, and close door while keeping switch up. This only worked for a while before the motor was toast.
Old Aug 11, 2006 | 07:16 PM
zzz350zzz's Avatar
zzz350zzz
I tried it and it didn't work. Is it possible for the switch to go wrong? I have already order the switch. It cannot be returned after installation.
thanks
Old Aug 11, 2006 | 07:32 PM
ZU L8R's Avatar
ZU L8R
Viper Sellout
Should be the motor. Does your car have warranty?
Old Aug 11, 2006 | 10:54 PM
zzz350zzz's Avatar
zzz350zzz
unfortunately, car's out of warranty. I'll order the motor and return the switch
Old Aug 11, 2006 | 11:01 PM
silver nismo's Avatar
silver nismo
Default Hey man
Originally Posted by zzz350zzz
hi,
I would try the switch 1st it seems its that all of us has suffered this. hold the switch up as if u r closing it and then tap the plastic where the switch is not the door but the same plastic it self thats what make it work for me.
Old Aug 12, 2006 | 06:44 PM
zzz350zzz's Avatar
zzz350zzz
is it possible for the switch to go wrong? How likely compared to the motor? I don't want to waste money to replace something still working.
thanks
Old Aug 12, 2006 | 06:48 PM
zzz350zzz's Avatar
zzz350zzz
does anybody have to replace the switch? my windows won't go up. I do not know what to replace? the motor or the switch? thanks
Old Aug 12, 2006 | 06:57 PM
Jcolman's Avatar
Jcolman
thanks
I'd put money on the motor clogging up as described in the other thread on this topic. It's a fairly easy fix that you can do in about an hour with simple hand tools. See below thread for directions.
www.my350z.com/forum/showthread.php?t=142013
Old Aug 12, 2006 | 10:57 PM
silver nismo
Default Its not the switch
thanks
The hook or jeck i realy dont know what to call it for you the plastic thing that has the wiers attached to it and then it clips into the switch check this 1 out 1st then the switch then the last thing you will do is the motor. and talking about wasting money well i think if you check the switch 1st is cheeper than changing the motor.
If the wieres attached to the clips that goes on the switch r loose then the motor is not geting any electric current to work and by default you would think its the motor thats what i think is the cheepest to do and check for the moment. take care and i hope this was helpfull.
Rev_Night
Nov 7, 2020 06:00 PM
HoBrahYouStink
Jun 24, 2016 10:58 PM
hulkout
Tuning
Sep 30, 2015 12:33 PM
samansharif
Sep 25, 2015 12:31 PM
