Condensation in the headlight.
Old Sep 19, 2006 | 04:14 AM
TIGHT-Z's Avatar
TIGHT-Z
Default Condensation in the headlight.
NIm out of warranty and nissan wants $1,200 to replace and install new headlights!!!! Does anyone know a cheaper and better way to fix this issue
Old Sep 19, 2006 | 08:19 AM
Eazzy's Avatar
Eazzy
Because of condensation ? Since u dont give ur location, that hinders me a little not knowing what ure atmospheric conditions are.
The head lights have, on the upper rear, breathers. If they are obsructed conden. has no way to get out. If they are working right,when u burn the lights it will disapate the moisture.
The lens can be removed if it gets to that, and dried, then reassembled.And when I say dried i mean over a 24 hr period. Although, the assy is put in an oven to loosen the lens so that will start the drying process.
BTW--If all else fails, I have a real nice set of non Xenons that can be converted using ur parts to Xenon
Old Sep 19, 2006 | 10:36 AM
VO...'s Avatar
VO...
Administrator
He's more than likely talking about the def that some of the older model 350Z's have. My 2003 Z has a haze in the headlights that won't go away also. There's not too much one can do about it, other than take it apart or replace them.
Old Sep 19, 2006 | 10:39 AM
Eazzy's Avatar
Eazzy
If so --- I buff mine out with an electric buffer and compound and they look like the day they were new.
COST: $4.00
Old Sep 19, 2006 | 04:24 PM
TIGHT-Z's Avatar
TIGHT-Z
No its def condensation, water is dripping in the inside throughout the whole headlight. I was going to take it apart and bake it, but is it tough to take out the headlights? Im pretty mechanically sound, i do all my work myself.
Old Sep 19, 2006 | 04:30 PM
Eazzy's Avatar
Eazzy
Well -- I just dont understand what the deal is then -----Taking them out ??? Just nuts and bolts ---Bumper has to be pulled bac-Inner fr wheel well has to come out---Plugs unpluged ---
Old Sep 20, 2006 | 05:53 AM
VO...'s Avatar
VO...
Administrator
If it is condensation, then I believe you have a bigger isssue... If the headlights have built moisture already, and the lights haven't evaporated it already, I believe your problem will return...
Old Jun 28, 2007 | 01:46 PM
splby's Avatar
splby
its starting to show in my 03' also. what can remedy this???
Old Jun 28, 2007 | 02:03 PM
Eazzy's Avatar
Eazzy
The headlites have a breather, its on the back,rubber and u -shaped, it has a small filter in it. If it obstructed....clear it....it pulls off. Then if you have condensation, burn ur lites until it disapates,nite and day.
Old Jun 28, 2007 | 04:04 PM
guy121's Avatar
guy121
Or you can remove it, oven bake it, install some clear corners, seal it up with some black silicone, hairdry the hell out of it, then put it back.
Old Jun 28, 2007 | 04:42 PM
Mazinger Z's Avatar
Mazinger Z
Just look for a DIY on how to open up your headlights...might as well paint them as well. Clean it up good, seal'em up and you're problem is gone.
Old Jun 28, 2007 | 05:38 PM
KornerCarver's Avatar
KornerCarver
Last weekend I was looking at my headlights and thought they were getting a haze on the inside. Mine is an '03. I decided to use some Meguiars PlastX and all the haze came off. It was on the outside so now the headlights look like new.
Hazing of the headlights is pretty common on most cars and there are lots of products in the auto parts stores to get them clear again.
Les
Old Jun 28, 2007 | 05:45 PM
splby's Avatar
splby
good info thanks.
Old Jul 4, 2007 | 11:40 AM
nepox's Avatar
nepox
check out 350 tech website from wiki, it's in the electrical part, they have a good tutorial in how to remove your headlights.
something similar happened to my Z, inner passenger fender fell off water got into the headlight. ballast might have fried, need to take out the whole headlight, dry out the ballast, replace bulb.
Eazzzzzzy PM sent i might need that right headlight
Old Jul 9, 2007 | 02:05 PM
xxbrokkxx's Avatar
xxbrokkxx
I had that on my 2003 also but its not water under the headlights its uv damage. you can buy meguires plast-x and put it on a micro fiber towel ( works best ) and just give it a good wipe down.
bcoffee20
Nov 19, 2015 06:39 PM
seanrulz
Oct 29, 2004 10:23 AM
WayneTN
Mar 11, 2003 08:48 PM
rtmitche
Oct 8, 2002 11:24 AM
