Click / creak sound?
on
I had my tires changed on 07 Jun 06. Ever since, I have had this clicking or creaking sound that seems to be coming from the right side of the car. It does this as I pull forward, even after each shift? My mechanic said it is the Calipers shifting...? He said the Quest van has that problem...Anyone have an issue like this? I know it was not there before tire change. Any help would be greatly appreciated.
on
i had a problem with my 350zr 05 every time i shift gears i hear a bad clicking sounds 1-4th gear as the weight of the car shifts and from the search i have done there is some kind of recall on that they should be able to fix it for free and i only had like 10k miles on my car
on
If it is a creaking sound that occurs when pulling away from a stop...then I had the same problem and it is a serious one. From the mouth of the dealer..this problem is based around the bolts that retain the axles. They become stripped from serious amts. of pressure placed on the drive wheels. This can result in your axles slipping right out of the side of you car! Get it checked!!!!!!!!
Justin100
11-29-2015 03:58 PM
