Service Engine Soon + VDC Off + Slip Lights
Old Oct 16, 2006 | 07:32 AM
35TH ANY's Avatar
35TH ANY
Default Service Engine Soon + VDC Off + Slip Lights
Anyone else have all 3 of these lights stay on at start up and your car won't rev? I then re-start and the "VDC Off" and "Slip" go off but, the "Service Engine Soon" stays on and it runs normally. This has now happened twice in the last month.
Old Oct 16, 2006 | 07:39 AM
Combat350z's Avatar
Combat350z
Hmm I had something similar happen a few weeks back and it was because the wires that were connected to my maf were rubbing against my strut bar base and causing a short.
Old Oct 16, 2006 | 07:40 AM
kcobean's Avatar
kcobean
If the car won't rev, it means you're ECU is falling into limp mode. What mods do you have?
Old Oct 16, 2006 | 08:03 AM
DIGItonium's Avatar
DIGItonium
Ooh... please get the ECU codes!
Old Oct 16, 2006 | 09:49 AM
35TH ANY's Avatar
35TH ANY
No mods.
Old Oct 16, 2006 | 10:40 AM
kcobean's Avatar
kcobean
Does the ABS light also come on when this happens? It sounds like it's time for a trip to the dealer.
Old Oct 16, 2006 | 10:47 AM
Nismo 350z's Avatar
Nismo 350z
Get it checked out at the dealer.
Old Oct 16, 2006 | 11:00 AM
35TH ANY's Avatar
35TH ANY
The ABS light doesn't come on.
Old Oct 16, 2006 | 11:05 AM
doskiez's Avatar
doskiez
Dealer
Old Oct 16, 2006 | 12:42 PM
s31t8n8's Avatar
s31t8n8
I had a similar problem. My slip light, VDC off light, e-brake lights stayed on. I took it to the dealer and they said all they had to do was reset something. It took them a minute to fix.
Old Oct 16, 2006 | 12:50 PM
35TH ANY's Avatar
35TH ANY
Did your ECU go into limp mode?
Old Oct 16, 2006 | 01:21 PM
GreenE69s's Avatar
GreenE69s
That means your brake fluid is low. Those three lights came on when I changed my brakes and drained too much of the brake fluid. However, the OP has the check engine light on which is probably something totally different.
Old Oct 25, 2006 | 06:18 PM
chadalac350z's Avatar
chadalac350z
my car did this at nopi when i put it on the dyno , weird to only had 227 whp but car feels like it has more, i have a catback and cai. anyways all 3 lights were on then went off like 30 seconds later. i sometimes think we all bought a lemon in the z but i have had 4 z's and they all have their problems. but i love mine, anyways soon to have headers and test pipes cant wait to see the dyno........
Old Oct 25, 2006 | 06:35 PM
kcobean's Avatar
kcobean
It's perfectly normal after you've had your car on the dyno. The back tires spinning and the front tires standing still freaks out the computer. After you drive for awhile and the computer sees normal signals, it shuts off the lights.
That's different than this happening during normal driving.
Old Oct 31, 2006 | 04:23 PM
35TH ANY's Avatar
35TH ANY
For anyone interested, the verdict is in. It was code P2135 which is Throttle Position Sensor Failure. The throttle body was replaced under warranty. On the short drive home from the dealer, it seemed to rev more freely.
Old Oct 31, 2006 | 04:55 PM
Thumbs up
Good news.
Old Nov 5, 2006 | 10:20 PM
zrebel's Avatar
zrebel
err i have to take a trip to the dealer soon as well =\
Old Nov 6, 2006 | 04:24 AM
xNeo's Avatar
xNeo
This happened to me this morning too, I for some reason immediately checked my oil and it was fine. After I checked the oil, the VDC OFF and SLIP light turned off but the Service Engine Soon stayed on. Is it ok to drive to the dealership, I backed it up and it seemed fine…but I didn’t want to take any chances and just pulled right back into the garage and took my Jeep to work.
Old Nov 6, 2006 | 05:13 AM
kcobean's Avatar
kcobean
Per Nissan, if the SES light is not flashing, the car is ok to drive. You're fine to drive it.
Old Nov 6, 2006 | 05:16 AM
xNeo's Avatar
xNeo
Thanks, this is my first "new" car so it kinda scared me a little. I still have 2 years on the factory warrenty and I bought the extended warrenty, so nothing should come out of my pocket right?
