Weird noise coming from under the engine?
Old Nov 5, 2006 | 01:28 PM
AroundMyHorn's Avatar
AroundMyHorn
Default Weird noise coming from under the engine?
When i start the car it sounds like theres a tweety bird chirping through my engine bay. Could it be a timing belt? Anyone know what this sound could be?
myZter's Avatar
myZter
PREMIER MEM.FTW
maybe a bird is stuck in there? what mods u have
Old Nov 5, 2006 | 01:44 PM
AroundMyHorn
ha.. if it is a bird my dinner options will be solved. For real though, i have no mods so ???
Old Nov 5, 2006 | 02:07 PM
AroundMyHorn
bump
Old Nov 5, 2006 | 02:44 PM
TurboTrey's Avatar
TurboTrey
My car makes a similar sound. It isn't very loud but in my parking garage it is a lot more noticable. I think the easiest way to describe mine is it sounds like rolling a glass bottle on a table. Not vrey loud but it does have me thinking.
Old Nov 5, 2006 | 05:59 PM
AroundMyHorn
come on gear heads....wtf would i hear a chirping noise coming from my engine at start up....not to mention i saw smoke coming out my exhaust.
Old Nov 6, 2006 | 06:57 AM
AroundMyHorn
bump
Old Nov 7, 2006 | 12:37 AM
702Fairlady's Avatar
702Fairlady
I have the same problem. It sounds like a squeaky pulley. It was solved once by my mechanic by using a chemical the kind of softens up the belt. It went away for a while but now is back again.
Old Nov 18, 2006 | 05:34 PM
jetpilot1's Avatar
jetpilot1
I'm pretty sure the VQ35DE uses a timing chain and not a belt....
Old Nov 21, 2006 | 05:36 PM
Eazzy's Avatar
Eazzy
No timing Belt !!!! What u are prob hearing is the main drive belt slipping-----Why ? U ask. Two reasons---
1. The belts cold, and as u drive it warms up and becomes "stickier"
2. U have just pulled ur Battery down by starting the Motor, and the demand for the alternator to replenish that lost voltage is causing a load. The harder ur alt. has to work, the harder it is to turn the rotor due to the increased magnetic field---Hence---Belt slippage, til it reachs its full charge and the Alt can relaxe a little.
Get a new belt like a Gator Belt and tighten it like a guitar string. Tweety will leave and nest elsewhere.
Old Nov 21, 2006 | 05:40 PM
Eazzy's Avatar
Eazzy
BTW----This is a quick fix that doesnt solve the prob,only hides it ---- A bar of soap on the contact area of the spinning belt does the same thing, and smells Spring Time Fresh.
Old Nov 23, 2006 | 02:12 AM
Azn_Empurio's Avatar
Azn_Empurio
i think this happens when ur car is cold
it happens to mine but after i drive for a bit and park, come back and restart, its very smooth
Old Dec 6, 2006 | 09:56 AM
meshugineh's Avatar
meshugineh
I get the same thing. I was planning on changing the belts anyway, I'll try these gator belts and see if it works. i'll let you know if it solves the problem.
Old Dec 7, 2006 | 04:43 AM
Lsmith9523's Avatar
Lsmith9523
I guess tweety bird came to visit my engine yesterday morning! I started out and all of a sudden,," I thodt I saw a puddy tat",,,Jking,,,,No, it started to chuurrrpp,,,,chuurrrrpp,,,then would go away, I sounds like the post above,,,where the belt is cold,,,and as it warms up the sound goes away.....This was my first time to hear it and I immed starting laughing cause I thought of this thread....LOL
Old Dec 7, 2006 | 04:53 AM
Eazzy's Avatar
Eazzy
AH ---Tweety found a new nest
liqalu04
Jan 2, 2022 12:58 PM
Fixxxercask
Nov 9, 2015 11:10 AM
kyin
Oct 15, 2015 05:54 AM
samansharif
Sep 25, 2015 12:31 PM
