Weird sound when giving throtle
Old Nov 7, 2006 | 03:51 PM
bigdog1250's Avatar
bigdog1250
Default Weird sound when giving throtle
I don't know if this is how it is supposed to sound but just want to check, and get some ideas. When I step on the gas (even a little) it kinda sounds like I have a turbo (which i don't), makes this little sucking sound from the hood. Only noticeable with the windows down. any ideas?
Old Nov 7, 2006 | 03:54 PM
bigdog1250's Avatar
bigdog1250
it might just be the fuel pump, but im not sure
Old Nov 7, 2006 | 04:07 PM
Ianmtx's Avatar
Ianmtx
You wouldn't happen to have a turbonator would you?
Old Nov 7, 2006 | 05:09 PM
benwa02's Avatar
benwa02
i got something similar....its like a quick whistle in like 3-6 gear when I hit the throttle too...doesnt do it all the time though
*2006
Old Nov 8, 2006 | 01:33 PM
bigdog1250's Avatar
bigdog1250
mine is in every gear. and yea I have 2 turbonators on my z! I don't think its problem at all, but just wanted to check. Probably just fuel.
Old Dec 11, 2006 | 10:32 AM
bemelvin's Avatar
bemelvin
I have the exact same problem on my Z. It's only in the morning when the motor is cold.
Old Dec 11, 2006 | 05:36 PM
06r33z's Avatar
06r33z
have the same problem when engine is cold maybe its your pilot bushing took my car in to the dealer but havent went back to get it fixed
Old Dec 13, 2006 | 05:25 AM
Sullyz's Avatar
Sullyz
I recently had the same problem with my 2006 Base DB. When starting from the house when weather is about 32-36 degrees, I get a howling type noise for the first few miles. When it's warmed up, it seems to go away. I know, why am I driving the Z in that weather, my wife has the SUV that has heated seats. Has anyone had the same problem, or have an answer. I haven't had the time to return it to the dealer yet. 10K miles. SullyZ
Old Dec 13, 2006 | 05:35 AM
Monsta's Avatar
Monsta
Not to be sarcastic, but are you talking about the intake sound? That is normal.
Say when you blow out candles, you make the small hole with your lips. When you breath, your lips are open wider. Same principal with the throttle plate. Diff is air is going in.
Am I too basic or is this what you mean?
Old Dec 13, 2006 | 06:08 AM
chishifu's Avatar
chishifu
^ +1, that's what i was thinking. It happened to me when I got a new intake. Just takes getting used to if that's the only problem.
ChiShi
Old Dec 13, 2006 | 08:15 AM
Sullyz's Avatar
Sullyz
It's not the intake sound. I've had the car for nearly a year, and have 10K miles on it. It's due to the cold weather.
Obadabot
Jun 18, 2023 11:31 PM
Uriyo_
Sep 8, 2021 08:46 AM
