Having trouble getting resistor to shut off airbag light
Old Nov 7, 2006 | 09:28 PM
nofeardude87's Avatar
nofeardude87
Default Having trouble getting resistor to shut off airbag light
So today I installed a race seat on the driver's side and I installed each side of the 2.2 ohm resistor to the airbag harness so that one side of the resistor went to one wire and the other side went to the other wire. I turned on the car and the airbag light was on so I tried to airbag reset procedure alot of time and nothing worked. Can anyone give me some advice? Thanks!
Old Nov 8, 2006 | 01:27 AM
nofeardude87
Here is a pic of the resistor
Old Nov 8, 2006 | 10:33 AM
Rog1206's Avatar
Rog1206
I did the exact same thing you did and couldn't get it to work.
Old Nov 21, 2006 | 02:19 PM
nofeardude87
still having the same problem...should I just try to stick the two ends of the resistor in the harness? I know it sounds stupid but I recall seeing a member here doing that and it worked.
Old Nov 21, 2006 | 02:40 PM
Rog1206's Avatar
Rog1206
Try it and see what happens. I'm thinking that we didn't use those tap in connectors properly?
Old Nov 25, 2006 | 06:41 PM
nofeardude87
I think I may have found the problem. I realized that I was using the WRONG resistors. I bought resistors with 2.2K ohm which is 2200 ohm but we are suppose to use 2.2 ohm total resistance. I couldn't find any 2.2 or 2 ohm resistors at radio shack so I think we both might have the same problem.
Old Nov 25, 2006 | 08:42 PM
That is some serious resistance!
Old Nov 26, 2006 | 01:13 AM
nofeardude87
Yeah, I finally solved the problem today. Since I couldn't find any 2.2 or 2.0 ohm resistors at radio shack, I just bought 10 10 ohm resistors (5 for each side) and soldered the ends together to get a total resistance of 2.0 ohm. Basically, I followed the directions on this old thread (scroll to the writeup on the bottom of the page) https://my350z.com/forum/showthread....light=resistor
So yeah, Rog1206 you should try check what kind of resistors your using to see if it is 2.2 ohm or 2.2k ohm.
loudtoyz
Apr 6, 2023 04:52 AM
Uriyo_
Sep 8, 2021 08:46 AM
350z82
Oct 1, 2015 06:25 PM
Sleeper_Z
Sep 30, 2015 10:25 AM
samansharif
Sep 25, 2015 12:31 PM
