Chattering sound when clutch is released
Old Nov 8, 2006 | 11:57 PM
Z-kid951's Avatar
Z-kid951
Default Chattering sound when clutch is released
I just recently bought a used base 350z. I recently noticed chattering sound coming from the engine bay when ever the clutch is released and then goes away and the clutch is pushed in. Usually very loud after I punch it for a lil bit and also hear it rattling when i accelerate. Im thinking its the Throw out bearing,
but then i took it to the dealership and they said its normal? but somehow i dont believe them.... am i just paranoid or are the techs at the dealership dont what they r doing? thx ^^ new to the forums btw nice to meet u all
Old Nov 9, 2006 | 12:51 AM
NissanZfan's Avatar
NissanZfan
Normal, I have the same sound.
Old Nov 9, 2006 | 12:52 AM
Joey47's Avatar
Joey47
I hear new sounds everyday. still drives good though. I guess its normal.
Old Nov 9, 2006 | 05:40 AM
VO...'s Avatar
VO...
Administrator
sounds kinda normal to me.
Old Nov 9, 2006 | 07:06 AM
03performz's Avatar
03performz
Normal. I hear that it's worse if you get a lightened flywheel. My dads stang has the same chatter.
Old Nov 10, 2006 | 11:26 AM
Clover350Z's Avatar
Clover350Z
It is normal. The rattling noise should be less as you give it gas. The stock flywheel on the car is actually two peices and is made to reduce noise by 400% and it still has some left. I have the nismo lightweight flywheel on mine now and the rattling is a lot louder in low rpms.
Old Nov 10, 2006 | 11:35 AM
disturbed2483's Avatar
disturbed2483
normal, i have a lightened flywheel and now it sounds like cement mixer.
Old Nov 10, 2006 | 11:42 AM
Smoove's Avatar
Smoove
I have the same noises, I was fetting ready to post the same question. The sound does bug me. It sounds like something is wrong, but if most of the Z's out there have have the same noises I will just leave it alone.
Old Nov 11, 2006 | 01:02 AM
Z-kid951's Avatar
Z-kid951
ok kool, was kinda getting worried but damn it gets annoying
Old Nov 14, 2006 | 12:42 AM
9kFever's Avatar
9kFever
so does this include when the car is in idle?
I noticed something similar when I was parking my car in the garage. When the clutch is engaged (not pushed in) i hear a noise (chatter) and when the clutch is disengaged (pushed to the floor) the chatter goes away.
Old Nov 14, 2006 | 05:07 AM
sorphin's Avatar
sorphin
back when I used to have a MINI, they said it was the 'mass of my gears rattling'.. I know cars and i don't buy that line itself, but it seems to be normal with both cars.. heh same as above post though, push in clutch, it goes away
Old Nov 19, 2006 | 10:18 AM
emtae's Avatar
emtae
I noticed a noise with mine when driving beside a building wall. The echo off the wall ( like going through the Mcd's drivethrough) Dealer told me there was no problem also. Sounds kinda like a throw out bearing clatter.
Old Nov 24, 2006 | 08:41 AM
SteveZ's Avatar
SteveZ
flywheel chatter - not normal with dual-mass stock OEM flywheel, very common with lightened FW's. Not likely TOB, unless you have some high miles.
Old Nov 24, 2006 | 08:54 AM
Swiffer's Avatar
Swiffer
Mine has been doing that since day 1
Old Dec 10, 2006 | 04:19 PM
350redline's Avatar
350redline
Yep, i dont think you should worry about it. Somedays my car will sound like a damn John Deer tractor, but i have noticed it goes away when you turn the AC on.
Old Dec 10, 2006 | 06:10 PM
bacalhau16's Avatar
bacalhau16
I always just called it clutch chatter, but I suppose flywheel chatter is the same thing. As I understand it, the flywheel is still spinning as the motor is idling, obviously, and the clutch kinda rubs against it slightly or just rattles slightly. When you depress the clutch pedal it goes away, and is common in a lot of standard cars. Atleast the many that I have owned!
Old Dec 11, 2006 | 03:30 AM
SteveZ's Avatar
SteveZ
Probably because AC kicks the idle up a notch in rpm. I noticed for some reason my base idle dropped when I did the replacement, it idles ~500 rpm, about 100 rpm lower.
Whatever little noise I can hear, it's more noticeable at 400-500 than 600-700 rpm.
Old Dec 11, 2006 | 03:47 AM
Jay'Z's Avatar
Jay'Z
I have mega chatter too!! I know its normal though, people keep insisting to me (know it all friends) my throw out bearing is bad!! Im like, yea ok.. You dont have a Z how TF do you know, my car has done this since day one and I know its normal!! Nismo clutch/flywheel is especially loud!
Obadabot
Jun 18, 2023 11:31 PM
07ZEKE
Aug 23, 2021 09:15 PM
Justin100
Nov 29, 2015 03:58 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
samansharif
Sep 25, 2015 12:31 PM
