Problem with the dumby lights in my speedo..
my car was cold today when i got in and started it and my low air pressure dumby light was on but i knew i had to go fill my tires up cuz i have a leak in my left rear tire so i let it warm up a little and started driving all of a sudden the emergency brake dumby light came on....then the VDC OFF light was on and SLIP light was on and they werent going off...when i parked and shut it off then waited and started again they didnt come back on....
but as i was driving i had to slam on my brake and the emergency brake light came on and went off...does that mean something? or any reason y any of these lights came on or does the cold weather screw up the electronics?
i know it screwed up my DVD navi door last winter...but now all these lights came on...
any ideas??
any ideas??
If your brake fluid level is low, that definitely explains why your emergency brake light came on.
You should check your brake pad levels. Usually when the brake fluid gets low its either because you have a leak somewhere or its time for new pads.
any reason why the VDC and SLIP light were staying on? i duno what that was about
Originally Posted by 350zz053
yep they all work together as one system. This happend to me...filled the brake fluid up. all better
i kind of figured they were all tied into the same thing
