View Poll Results: problems youve had with your 2003 350Z.
Paint
199
28.88%
Transmission
180
26.12%
Tires
281
40.78%
Suspension
121
17.56%
Interior
179
25.98%
Heating and Air conditioning
26
3.77%
4.21%
Radio
133
19.30%
Electrical Systems
58
8.42%
NONE
108
15.67%
I VOTED!
133
19.30%
Multiple Choice Poll. Voters: 689. You may not vote on this poll
Current/past problems with your Z.
Old Jun 23, 2004 | 08:15 PM
  #141
Losing Grip II's Avatar
Losing Grip II
Originally posted by lunartick13
NONE OF THE ABOVE,
I have 4000 miles on my Z and ZZZZZero problems.
dont worry they will come.....
tomorrow i take my Z in, before i leave for bonaire, to have them replace or fix:
Grinding 2nd Gear
Replace B oth Seats
Fix the "clunk" nopise from the from suspension
Fix my broken clip thats holds the interior part of the door
Fix the LOUD clutch chatter at start up * due to failed synchros*
at 896 miles suspension "clunk" began... still have it! (after they said they fixed it twice!)
at 6000 miles i had no trouble.
at 7000 the tires went
at 9500 driver seat went
at 11000 tranny went
at 11000 both seats began to rip
i love my Z!
haha
john
Old Jun 24, 2004 | 05:59 AM
  #142
Kari's Avatar
Kari
- cluch noise when neutral
mechanic compared with other 350Z, same noise, he concluded as normal, no fix. [/B][/QUOTE]
I had the same clutch noise when in neutral, just had my transmission and clutch replaced by Nissan three days ago and mysteriously the clutch noise went away. If its the same noise that I experienced it sounded like a loud rattling when in neutral. I have 17k miles on my Z and 3rd gear started grinding about 3 weeks ago. Took it into the shop, they replaced it, no questions asked. So I would probably say that you are going to experience the grinding in your gears sometime soon and when you do, take it right into the shop and say "my transmissions bad". They wont even question it.
Old Jun 24, 2004 | 03:44 PM
  #143
Pit Bull's Avatar
Pit Bull
I have 7K miles on my Z, I'm not concerned since it came with a 5 year 60K miles drivetrain warranty. Mine is fine so far.
Old Jun 25, 2004 | 05:12 AM
  #144
Juztin's Avatar
Juztin
Well the new problem and one that I seem to be the only one with is...
@ 3500 miles my vq ate atleast 2 whole quarts of oil. There are no leaks anywhere. The vq itself has 47k miles on it now. But I noticed this because of my thread regarding oil pressure where I first noticed an immediate problem.
I can't tell if the engine is just eat a lot of oil, or if it's something else. The engine seems to respond just fine and go about merrily, but this is the first time I've had something like this happen so it may be a little to early to see what up. Another memeber mentioned that motors have been being replaced for this problem which is not what I wanted to hear.
I'm going to need to start tracking my oil consumption at each oil change and see if there's a pattern, or if it was just some kind of odd one-time-occurance. I ran pretty hard during the 3500 miles, but I've also been running hard since I finished my engine break-in. Either way... there may be a new problem in the future for the vq... dunno yet
Old Jun 25, 2004 | 01:30 PM
  #145
Pit Bull's Avatar
Pit Bull
Take it to the dealer and have them note the problem, they will track it. I would do this now since you are 12K miles from the end of your warranty. I would tell the dealer you noticed the loss of 2 quarts in 1000 miles, so they don't blow you off with 1 qt. every 1500 miles is normal. You want them to track this useage and resolve the problem. By the way how often do you check your oil?
Old Jun 26, 2004 | 02:17 PM
  #146
omarv6's Avatar
omarv6
Hi guys ...am new here just came in today looking for a reson for my problem wich I have in my 2 week old Z...I hope u guys could help !!
Ok now i hear some kind of whining sound inside my car I dont know if it was from befor or just came up now .
it starts if i press the gas a bit and RPM go's over 3000...
it sound like a long blow of valve sound its kinda of a metalic sound..
my friend says it sounds like a supercharger ..... I dont know where is it comming from am sure it has to do with the tranny!!....if the car is stoped ... and rev the engin its not there...i have to be moving !!
can you guys help......and is the car suposed to be like that !!
thak u all
Old Jun 26, 2004 | 06:33 PM
  #147
Pit Bull's Avatar
Pit Bull
Hard to address noises over the internet. Unless you can post the sound. What is long blow of valve sound? I would suggest you take it to the dealer and have them check it out. If they say it is normal have them take you for a test drive in another new Z that they have on the lot and show you the same sound. Since they are the ones that will have to deal with it I would start with them.
Old Jun 30, 2004 | 09:27 AM
  #148
Zenvy's Avatar
Zenvy
MY PROBLEMS
1. Grease streaks both windows (don't feel comfortable letting them remove door panel and stuff)
2. Tire feathering (replaced twice-waiting for my second replacement tires-national backorder!) every 5-7K miles
3. Bose stereo-Bass (amplifier replaced)
4. DRIVER'S SIDE WINDOW AUTO-UP MALFUNCTION (WILL GO ALL THE WAY UP AND THEN GO A 1/3 OF THE WAY BACK DOWN...MOST OF THE TIME )
5. Rattling noise in interior (Passenger airbag-metallic tinging)
6. Excessively bouncy ride on concrete smooth roads (ANYONE KNOW OF THE CHEAPEST, BUT RELIABLE, SUSPENSION MOD TO ELIMINATE THIS?)
7. AC sometimes does not work (loud noise (compressor?) when turned on at idle)
8. Had tranny replaced after 2nd-3rd gear grinding
9. Excessively soft paint/clear coat
10. Side plastic molding on driver's seat broken (will be replaced soon)
I'm kinda getting depressed right now...i'm gonna stop making my list.
Old Jul 7, 2004 | 02:41 PM
  #149
pmf123's Avatar
pmf123
Making a high pitch noise 79-81 mph
Clicking when i turn the wheen full turn one way or the other, plus a slight click if i have to break hard... suggestions??
walfordweb@aol.com
Old Jul 7, 2004 | 04:25 PM
  #150
Pit Bull's Avatar
Pit Bull
walfordweb@aol.com
Could be the clock spring for the air bag, never heard of this yet in the Z?
Old Jul 9, 2004 | 06:09 AM
  #151
pmf123's Avatar
pmf123
Its very similar to when a CV joint went on my old Celica....
Old Jul 11, 2004 | 05:59 PM
  #152
Riv350's Avatar
Riv350
had a weird electrical malfunction. When starting I hadn't depressed the clutch far enough, as i depressed it further the starter engaged and at the same time i slightly let off the clutch and the main fuse (120amp) blew. I took the entire fuse block to the nissan dealer and he accused me of trying to jump the battery wrong and that's what blew the fuse. I explained what I did and stated "why would i make up such a story" Has anyone else experienced such a problem. I am curious to know if there is a hidden problem with the electrical starting system. Thanks
(2003 Ent. 6 spd)
Old Jul 13, 2004 | 06:53 AM
  #153
FLZ's Avatar
FLZ
Default VIN
Originally posted by Boomer
What do you want to know? You can do a search, start back in '02, you may want to ask a Moderator in a PM.
Hey Boomer. Go to www.courtesyparts.com They have the sheet.
Old Aug 4, 2004 | 03:30 PM
  #154
richc86's Avatar
richc86
has anyone heard of a ticking sound coming from the engine, I remeber my 96 honda did it at a point in time and I had the valves adjusted, but the Z is to new for this. Also dealer stated it's the Fuel Injectors and that is normal
feed back please!
Old Aug 4, 2004 | 04:44 PM
  #155
FLZ's Avatar
FLZ
Could be a valve tap. Keep checking your oil. What oil viscosity do you use? Brand too? Dave
Old Aug 5, 2004 | 04:45 PM
  #156
richc86's Avatar
richc86
I just had the oil changed at the dealer, I had the ticking sound before the oil change then I made an appointment for later that week for tranny and engine tick. They replaced the tranny with Nismo but said the ticking was normal (I doubt that it's normal I hang with a whole bunch of Z's and I do not hear the sound from their Z's) Anyways when I first changed the oil I used the Mixed Syn and regular it was one of those 10 Min oil change shops ( had no choice reached 3k) It was Valvoline, do not remember the viscosity. Now it has Castrol synthetic 10/40 or 10/30 not sure.
What's a Valve tap?
Old Aug 6, 2004 | 03:09 PM
  #157
FLZ's Avatar
FLZ
Default re: valve tap
What's a Valve tap?
Sorry, didn't mean to scare you. it's not a big thing, and probobly not the sound anyway. In the old days , sometimes you could here a ticking sound from the valves. No biggie. Also, Living in FL, (me too),I tend to use a heavier viscosity oil, like 50 weight. Just better lubrication, especially in our hot weather. and with a performance motor. GL to you. Z Ya! "FLZ", Dave B
Old Aug 6, 2004 | 07:06 PM
  #158
richc86's Avatar
richc86
Thanks Dave, yeah I used to stay in Boca myself.....about 1 year and a half ago. hey there is a Z meet in Miami on 8/15 if you're interested, we're going to convoy down there....
Old Sep 3, 2004 | 12:47 PM
  #159
Juztin's Avatar
Juztin
*PS/ALT side tensior pulley replaced (fell off during driving)
-wasnt fun to loose power steering while taking a sharp corner at 60mph when it happened
*Tranny replaced for grinding (1st-2nd, into 6th when cold)
*Shifter assembly replaced (busted the shifter while shifting spiritedly)
*Left quarter axle replaced
*AC stopped working (not engaging)
*Clutch assembly replaced
(Now I have a CRACKED borla true dual exhaust)
I was hands off about the oil until I lost so much, oddly I have not been noticing any consumption since... weird. Been checking the oil levels.
Old Sep 3, 2004 | 12:49 PM
  #160
Juztin's Avatar
Juztin
I also had my RPM tach get "stuck" at around 3k rpms twice before. It would start working after a while (2-5 minutes) was odd but hasn't done it since. Been about 2 months since it happened.
