help on alert sound!!
Old Dec 30, 2006 | 04:32 PM
Red350ZPR's Avatar
Red350ZPR
Default help on alert sound!!
My Z is throwing an alert sound everytime I start driving. Is like 1 min later I start the engine and I'm on my way. Is a similar sound as the headligth sound (when you leave them ON while turning off the engine). Is like a Beeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee eeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeppppp for about 10 sec. It cant be the pads since I change them yesterday (12/29/06). I also reseted the ecu yesterday and nothing happen.
What can it be and/or what can I do to make it stop??
Thanks for the help!!
Old Dec 30, 2006 | 05:20 PM
Lsmith9523's Avatar
Lsmith9523
did your tire pressure monitor light up? I know in my Titan,,when the temp would get cold,,,my pressure light would come on and it would give off this long, annoying beep....just my quick thought......So far my 06 Z's pressure monitor is doing ok.
Old Dec 30, 2006 | 06:35 PM
Red350ZPR's Avatar
Red350ZPR
Well my "psi" light in the multisensor gauge is always Blinking. but as far as I know there's no alert sound for psi. However I'm not 100% sure. But I really want to fix this up. BTW in my dash there's NO lights on.
What could it be??
Old Jan 3, 2007 | 10:36 AM
Red350ZPR's Avatar
Red350ZPR
Anybody have an idea??
Old Jan 3, 2007 | 10:42 AM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
Obviously it's the tire pressure sensors. Either you took them off your car (aftermarket wheels) or they stopped working, or your pressure is dangerously low.
THE TECH's Avatar
THE TECH
Owner's manual anyone???
Old Jan 5, 2007 | 01:25 PM
Red350ZPR's Avatar
Red350ZPR
I read the owner's manual twice and there's no alert sound for tire pressure. There's only 3 reasons why the Z give an alert sound, and those are; If (1)you leave the lights on when you turn off your car (2) If you leave the key in the ignition and (3) if the pads need to be changed. So I think that the tire pressure is not the problem that is causing the car to beeeeppp for 5 sec. BTW my tire pressures are Front 33---32 Rear 29----28.
Correct me if I am wrong, and if somebody have an idea polease help me out!!
Thanks!
Old Jan 7, 2007 | 11:11 PM
Red350ZPR's Avatar
Red350ZPR
any clue friends?
Old Jan 7, 2007 | 11:17 PM
UGOTZ'D's Avatar
UGOTZ'D
there is an alert for tpms that is a loud beep! that is what you are hearing!
Old Jan 8, 2007 | 06:12 AM
GonZ's Avatar
GonZ
I remember for a fact that the owner manual says there're beeps for tpms. They are two long beeps, each last 10 seconds.
Old Jan 8, 2007 | 06:15 AM
06blueZ's Avatar
06blueZ
And the car most definetly does not beep for low brake pads!
Old Jan 8, 2007 | 06:24 AM
stein's Avatar
stein
Wouldn't that be a nice feature though...
Old Jan 8, 2007 | 06:31 AM
GonZ's Avatar
GonZ
Now i'm starting wonder which manual you were reading?
Old Jan 8, 2007 | 12:45 PM
done12many2's Avatar
done12many2
Yeah, I think I missed out on that beep when mine got low.
Old Jan 8, 2007 | 12:51 PM
LeMans 05's Avatar
LeMans 05
I got a slow leak in one of my tires, trust me, there is a LONG loud beep when your tire pressure gets low, and your PSI on your gauge will start blinking. You should also get the (!) on your dash. It's all one reason - you've pissed off your tire pressure sensor, either by removing them, or you have a low tire.
Obadabot
Jun 18, 2023 11:31 PM
sales@czp
Sep 23, 2019 03:30 PM
wanderingstuden
Jan 28, 2016 07:03 PM
Justin100
Nov 29, 2015 03:58 PM
samansharif
Sep 25, 2015 12:31 PM
