Anyone had this happen already???
Old Jan 11, 2007 | 02:55 PM
MeetJoeAsian's Avatar
MeetJoeAsian
Default Anyone had this happen already???
Yesterday as I was driving out of my work place, I felt my tranny and acceleration lag a little bit and all of a sudden the "Engine Service Soon", "TCS OFF" and the "SLIP" lights all came on at once, and yes the lagging continued...so I pulled back to my work parking lot and shut off the car and started it again, and this time only the "Engine Service Soon" light stayed on....what was that???
Old Jan 11, 2007 | 03:47 PM
DavesZ#3's Avatar
DavesZ#3
Check the obvious and simple first - brake fluid and brake pads.
Beyond that it could be a problem with a wheel speed sensor, the ABS module or anything else related to TCS/VDC.
Old Mar 15, 2007 | 06:15 PM
knitoe's Avatar
knitoe
Default Just had this problem
This problem happend to me in my 04, it was the TPS replaced under warranty.
Old Mar 19, 2007 | 06:58 PM
MeetJoeAsian
Originally Posted by knitoe
This problem just happend to me in my 04 with 39700 miles... Did you ever figure out what it was? Or has anyone else have any ideas? I dropped it off at the dealer right away, but unfortunately the service was closed already.
it was the throttle body...they replaced it under my extended warranty...guy at dealership told me first it may be my brakes, but I had my brake and rotors replaced 10k miles prior....he checked it out and replaced it...
Old Mar 25, 2007 | 02:04 PM
Ichigo's Avatar
Ichigo
I have also experienced this. It started when I had my stock rims and potenza's on and I thought it might have something to do with my feathered tires. I've replaced them and the problem still exists. I have an 03 enthusiast and I was in 5th gear doing about 45mph today and dropped it into fourth to pass another car and the slip light lit up and cut power. My tire sizes are 255/35/18 Front and 275/35/18 in the rear. I have about 5k miles on my Hawk Pads and no VDC. Should I let the dealer investigate DavesZ#3 suggestions?
Old Apr 28, 2007 | 03:10 PM
THE ROADSTER's Avatar
THE ROADSTER
This just happended to me 2 hours ago.
my light is still on
Old Apr 29, 2007 | 03:21 PM
redss's Avatar
redss
Guys,
When you say it cuts power. How much power do you lose? Is it like 30% to 50% where you can still drive it safely to a gas station to restart or is it more like 80% where you are dead for sure if you are trying to cross a road with cars coming at you?
I do not have a Z, yet but I am playing with the idea of trading in my 2003 Mazda6S for one. The ironic thing about this is that my Mazda6S also do that and it has to do with the fly by wire throttle body similar to the one on the Z. Although when it goes limp, I cannot rev the car higher than 2000 rpm even with the gas pedal floored..
I thought this was just a "Ford" thing but not sure how it is for the Z?
07ZEKE
Aug 23, 2021 09:15 PM
apex locator
Jul 23, 2021 02:27 AM
3vilbunny
Jul 18, 2017 05:10 PM
HoBrahYouStink
Jun 24, 2016 10:58 PM
hulkout
Tuning
Sep 30, 2015 12:33 PM
