Listen to my video. Does your Z sound like this?
Old Jan 25, 2007 | 08:51 PM
black06z's Avatar
black06z
sounds pretty normal. mine does the same.
Old Jan 26, 2007 | 05:24 AM
drap660's Avatar
drap660
same here... Checked it out and its the injectors... Just wait till u get a utec or some sort of EMS where you can bump up the fuel.... Then you will really here them injectors like I do
Old Jan 26, 2007 | 05:52 AM
jjulich's Avatar
jjulich
How can we be so sure this is the injectors? Bare with me a second on this one.
If it was the injectors, they don't all fire at the same time, right? Really, what we woudl be listening to is just one injector, or one valve? But that doesn't make sense. Why would only 1 injector make this sound, or just one valve on all Nissan engines? If it would be all, if it was normal. The sound has to be coming from something in the engine that there is just one of.
Old Jan 26, 2007 | 06:02 AM
drap660's Avatar
drap660
If you hear one specific ticking sound like a valve check this... Have seen this to be the issue on many 350Z's... Nissan even has a article on it... If you feel the dampner it actually vibrates along with teh ticking noise...
http://www.nissanhelp.com/Ownership/.../NTB06-042.htm
Old Jan 26, 2007 | 06:43 AM
jjulich's Avatar
jjulich
IS IT THE FUEL DAMPER?
I've seen this, but they say the fix is only if you hear it on the interior. I don't hear the sound on the interior, only exterior. Could it still be the culprit? Has anyone had this fix and the sound on the exterior went down?
Old Jan 26, 2007 | 07:02 AM
drap660's Avatar
drap660
I mostly only hear it in the interior
Old Jan 27, 2007 | 06:22 AM
jjulich's Avatar
jjulich
The sound ticks 6 times per second, meaning it's something that occurs every 2nd revolution of the engine. I doubt it's a valve or injector, cause if it was normal, like your guys are saying, you should hear all of them, not just one.
COULD IT BE THE FUEL DAMPER?
Has anyone report if they had this replaced? Did this fix your problem? Did you have any ticking sound outside your vehicle and it went away with this fix?
Old Jan 27, 2007 | 02:42 PM
pedroosan's Avatar
pedroosan
Hmm... I can hear it both inside and at the engine bay in my car.
BTW in my case it does not sound like your ticking, but more like knocking.
(more like tock'o'tock'o'tock' and not like clicky'clicky'click )
I haven't figured it out yet, but also hope its normal.
Obadabot
Jun 18, 2023 11:31 PM
sales@czp
Sep 23, 2019 03:30 PM
wanderingstuden
Jan 28, 2016 07:03 PM
Justin100
Nov 29, 2015 03:58 PM
samansharif
Sep 25, 2015 12:31 PM
