Question On Changing Oil
Old Feb 1, 2007 | 02:17 PM
JFAIR's Avatar
JFAIR
Default Question On Changing Oil
i put about 200 to 300 miles a month on my car. i know the rule of thumb is 3 months or 3,000 miles. can you go longer then 3 months? what is the max untill oil starts to break down. the oil i use is 5w30 and i'm pretty hard on the car when i drive it. thanks in advance and i'm sorry if i postd in the wrong area.
Old Feb 1, 2007 | 02:19 PM
Swiffer's Avatar
Swiffer
I would go up to 6 months.
Old Feb 1, 2007 | 02:21 PM
JFAIR's Avatar
JFAIR
that is what i was thinking.
Old Feb 1, 2007 | 02:27 PM
Mazinger Z's Avatar
Mazinger Z
If you really value your car, I think you should go by what Nissan suggests you do - which is 3,000 or 3mo. Since dino oil is cheap, you could do an oil change for less than $15. Why take the risk of damaging your engine?
Old Feb 1, 2007 | 02:31 PM
JFAIR's Avatar
JFAIR
the miles i can understand. but oil sits on a shelf for months at a time before it is ever even purchesed. i know i should just suck it up and change it every 3 months.
Old Feb 1, 2007 | 02:33 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
check the top 100 questions thread for info about oil, filters, and changes. link is in my signature
Old Feb 5, 2007 | 06:38 AM
DJMatrix1067's Avatar
DJMatrix1067
best thing to do is 3 months of 3000 miles. maybe even less if you drive it hard and have dino oil.
my last oil changed i went to full synthetic 10w30 royal purple and the guy told me that if i continued to drive the way i do, i could probably get 5,000 miles out of it.
but i think ill probaly do it before that.
spend the extra 15 bucks every three months and get it changed properly, thats 5 dollars a month. if you cant handle that, then you shouldnt be driving a Z.
Old Feb 5, 2007 | 07:12 AM
dkmura's Avatar
dkmura
General & DIY Moderator
Another factor to consider is the kind of conditions you're operating your Z in. It's wintertime and cold temperatures, junk on the roads and in the air increase. All that contamination does have an effect on your oil (and more importantly) the oil additive package. The detergents in that package can encapsulate some of the grime that makes it into your oil, but only for a limited time.
Bottom line: you could stretch your oil/filter intervals to as much as 5K, but as many of the other posters here have already said, it's simply not worth it. Your VQ deserves better!
David Muramoto
Senior Editor
Nissan Sport Magazine
Old Feb 28, 2007 | 08:06 AM
gothchick's Avatar
gothchick
Hyrdo carbons still break dino oil down over time even if ur not putting miles on it, that's why they say 3,000 or 3 months. I'd change it, so the next guy that buys ur car won't have to do an engine swap for his first mod. If nothing else, it's just cheap insurance. :-)
issyz
Jul 2, 2017 03:04 PM
Glenn350zHR
Drivetrain
Nov 30, 2015 08:21 AM
SonnyWu
Nov 24, 2015 08:19 PM
kyin
Oct 15, 2015 05:54 AM
Mattg350z
Oct 2, 2015 06:51 AM
