help with rust dots on top of 350z
Old Feb 16, 2007 | 11:57 AM
n00bie's Avatar
n00bie
Question help with rust dots on top of 350z
does any know what should i do?
i have three little dot of rust on the top my 350z.
where should i go to fix it or how do i fix it?
here are some pictures of it.
Old Feb 16, 2007 | 12:38 PM
rockinbboy's Avatar
rockinbboy
Are you sure its rust? There have been posts about weird small dots on the roofs of our cars which has been pointed out to as rail dust or railtrack dust or something like that. I am not a 100% sure. If it is actual rust, then you should take it to a professional detailer because you don't want that to spread.
Old Feb 16, 2007 | 12:41 PM
Santacruzslick's Avatar
Santacruzslick
Veteran
It most likely is rust. I had one little spot like this. It originated from a rock chip that went all the way through to the metal. Just remove all the rust and put a tiny dab of touch up on it(if it's even big enough) or a little dot of clear to block moisture. Also keep it covered with wax or polish.
Old Feb 16, 2007 | 01:22 PM
n00bie's Avatar
n00bie
how do i remove the rust?
what do i put on it?
i don't know what touch up and clear is.
is there a place i can take it to get it fixed?
thanks
Old Feb 16, 2007 | 01:43 PM
This thread needs some photos.
Old Feb 16, 2007 | 02:47 PM
Santacruzslick
Veteran
There's a product called Naval Jelly that you can put over the rust spot, let it sit for a few hours then wipe it off. It should take all the rust with it. After that, depending on how big the spots are, you can apply a small amount of touch up paint to the area or just use a bit of clear coat. The purpose of this is to protect the area from getting wet and rusting again. After a few days apply a good coat of wax or polish over the area to protect if further.
Old Feb 16, 2007 | 03:00 PM
gunser's Avatar
gunser
Do your spots look like mine?
https://my350z.com/forum/showpost.ph...17&postcount=9
Old Feb 16, 2007 | 03:06 PM
n00bie's Avatar
n00bie
they look something like that.
i just found some more littler ones...
thanks for the help too
will try to post some pictures.
Old Feb 16, 2007 | 04:12 PM
n00bie's Avatar
n00bie
by the way where do i get naval jelly.
and also how much does it cost and where can i go to do it at a shop or by a detailer?
Old Feb 16, 2007 | 04:17 PM
diwun67's Avatar
diwun67
I have 3 spots on my roof as well, good idea about the naval jelly, I'm going to try that, already have the the touch up paint, just need some clear
Old Feb 16, 2007 | 06:52 PM
I am going to second the suggestion with an added step. After removing the rust, apply an undercoat of Rustoleum. You can buy it in a small bottle at Home Depot. Its in the appliance department. I use it on my car.
Old Mar 7, 2007 | 02:07 PM
stein's Avatar
stein
Well, I also have two small rock chips on the roof just above the windshield.
Can someone give a like to the Naval Jelly and touch up kit. I need to get this taken care of before it gets out of hand! I wonder if this is a good spot to place some clear bra material...
Old Mar 7, 2007 | 02:45 PM
Zquicksilver's Avatar
Zquicksilver
I can confirm the micro rust spots... I drive my Z year round here in Chicago (salt city). Now and then I will get a cluster of rust specs that appear to be on the top surface (clear coat), bizarre!! I can remove them with heavy rubbing or my fingernail. Its really weird… but I can see them and feel them after I clean the car and run my hand across the finish. They only appear on the roof and rear lid (steel). I can't explain it, but now I don't feel alone...LOL!
I have the 3M clearbra material covering half my roof, from the windshield edge rearward. I've had it for 2yrs now, I forget its up there. I think it helps
GL,
Zquicksilver
Old Apr 19, 2013 | 05:38 PM
Xonatron's Avatar
Xonatron
Reviving a very old thread, and all the pictures are now 404'ing, but this is happening to me too. I just found some tiny rust spots on the roof of my 350Z (2006). I'd like to take care of it. I'm going to bring it to someone else to do. Any help is appreciated and I'll forward the advice given above.
sales@czp
Suspension
54
Jan 17, 2018 09:24 PM
Vigman
Nov 17, 2015 04:34 AM
Mattg350z
Oct 2, 2015 06:51 AM
BumbleZee
OZOC (Orlando Z Owners Club)
Sep 26, 2015 01:00 AM
