Difficult to engage first & reverse gear only when car is running
Old Apr 10, 2007 | 03:26 AM
leeboyNY's Avatar
leeboyNY
Kimchi Eater
I had the same problem.. Fixed it by adjusting the clutch engagement point.. Because I drift occasionally, my flywheel goes through lots of heat cycles and in result, it warps in time. So, after a while even if I press the clutch in, it does not fully disengage.
Old Apr 10, 2007 | 09:48 AM
Cloud's Avatar
Cloud
adjusting the engagement point didn't do anything though...
Old Apr 10, 2007 | 10:52 AM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
Originally Posted by Cloud
even after the car has warmed up the problem persists.
That's why I suggested swapping transmission (and while you're at it, differential) fluids
Old Apr 11, 2007 | 10:10 AM
Yancy's Avatar
Yancy
It is easy to shift into all gears when the car is turned off but it is hard to shift especially into first and reverse gear when the car is running.
What could be wrong? The clutch line has been bled.
Possible issue with your release bearing?
Old Apr 11, 2007 | 07:07 PM
Cloud's Avatar
Cloud
The car still has a 6 year warranty on it... swapping the transmission sorta seems abit too much?
edit: fixed
Old Apr 12, 2007 | 11:01 AM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
The car still has a 6 year warranty on it... swapping the warranty sorta seems abit too much?
I think you missed the word FLUIDS.
And I also think you said "warranty" instead of "transmission"
Old Apr 12, 2007 | 09:00 PM
Cloud's Avatar
Cloud
lol yeah sorry , wasn't paying attention when typing.
Old Apr 13, 2007 | 10:14 AM
Changvi's Avatar
Changvi
Adrian, i want to check out your problem. I have that problem sometimes when its cold. Give me a call this weekend so i can check it out. Just got Unichip, going to have Rob tune it.
Old Apr 13, 2007 | 12:51 PM
arejohn's Avatar
arejohn
Difficult to shift into gear. Clutch not releasing completely or input shaft tight or binding in flywheel or defective clutch plate assembly IF clutch engages middle or above halfway. Does the z have syncros on reverse? Is it only the first time you put it in gear? Try -Car stationary, trany in gear, gears stop spinning. Now, with clutch still depressed, change gears, does the trany engage correctly now?
Old Apr 14, 2007 | 12:03 AM
Cloud's Avatar
Cloud
Hey vince, I lost your number, mind PMing to me? so we can meet up this weekend?
Old Apr 14, 2007 | 12:06 AM
Cloud's Avatar
Cloud
clutch engages at the very top.
For the little experiment, if I manage to get in gear smoothly, it will stay that way as long as i don't release the clutch pedal. The moment i let it out and try to get in gear again, It becomes difficult to get in gear.
Old May 6, 2007 | 10:18 PM
Cloud's Avatar
Cloud
Update: I found something very disturbing tonight.
On a level surface the car actually MOVED FORWARDS when I put(with alot of effort) it in 1st gear with the clutch depressed and BACKWARDS when I put it in reverse also.
Note that it only moves when I feel the resistance of putting it into gear, It's like I'm pushing the car with the shifter ??
Old May 7, 2007 | 08:29 AM
andypandy's Avatar
andypandy
clutch is still engaged. at the exact moment when you shift into gear, even with the pedal full depressed, the car will move according to the gear since the clutch is still engaged. take it back to z garage and have them fix it asap... you will wear out synchros in no time with this problem.
Old May 7, 2007 | 09:42 AM
Cloud's Avatar
Cloud
I don't know. I'm tired of ZCG already. Think the car will last till the 26th? Heading down to west covina nissan.
Old May 7, 2007 | 09:49 AM
andypandy's Avatar
andypandy
yes... will the time in between from then and now cause a lot of problems? more than likely.
is there a nissan dealership near-by?
Old Sep 30, 2011 | 10:30 AM
twinturbo666's Avatar
twinturbo666
Andypandy I'm having the exact same problems you did I can't get into gear and car rolls if I try, what was the solution please!!???
Old Feb 7, 2012 | 06:06 PM
Regul8or's Avatar
Regul8or
I hate to bring back an old thread, but I'm having the same issues on my car now. Its a 2006 with an aftermarket clutch and flywheel. JWT (installed august 2011). I had my clutch pedal adjusted about 4 months ago. It only started happening recently.
My car has been at the dealership for over 2 weeks getting repairs (hit a cinder block on the hway...) It wasn't like this before. Only once in a while.
I will be taking it back to the nissan dealership to try to solve this problem. It is exactly as Cloud described it in the posts above. It will NOT go into first unless I really push it in.
Any experience with this will be greatly appreciated.
Thanks,
Regul8or
pslamp32
Feb 8, 2017 09:07 AM
Mattg350z
Oct 2, 2015 06:51 AM
Bodyboarder81
Sep 21, 2015 06:23 AM
ThreeFiveZero Z
Sep 12, 2015 04:33 PM
