Car wont hold idle when starting up
Old May 19, 2007 | 07:25 PM
silviase7en's Avatar
silviase7en
Default Car wont hold idle when starting up
Hey guys recently my engine service light came on because of my aftermarket steering wheel and cam sensor. my mechanic told me it should be fine and to reset my ecu by unplugging the battery. i unplugged the negative for about a couple of hours and the light went away, but now when i start the car it wont hold idle and dies. when i start it up and rev it before its about to die, then it idles fine. i doubt it has to do with the cel light but maybe its the ecu? i have an intake and exhaust w/test pipes..anyone experience this problem? anyone know what it could be?
Old May 19, 2007 | 07:59 PM
DIGItonium's Avatar
DIGItonium
Cam sensor?
Old May 20, 2007 | 03:33 PM
silviase7en
doubt it bcuz it would throw the code again, anyone else?
Old May 21, 2007 | 06:29 AM
DIGItonium's Avatar
DIGItonium
Did any of your mod work involve fiddling with the e-throttle? It's one very expensive part to replace.
Old May 21, 2007 | 07:21 AM
silviase7en
nope. a friend suggested since i just reset the battery, my car needs to be driven for a little for my ecu to get used to my mods, only driven about 5-10 miles max after resetting..
Old May 21, 2007 | 10:10 AM
rpm06g35's Avatar
rpm06g35
Did you change anything on the motor? cause that sounds like you have a vacum leak. This just happened to me. let me know
Old May 21, 2007 | 10:44 AM
silviase7en
only things that i have on my motor is a arc intake with the arc pipe and hks exhaust with test pipes
Old May 22, 2007 | 10:09 AM
DIGItonium's Avatar
DIGItonium
Okay, I was just concerned when you mentioned cam sensor.
Old May 22, 2007 | 04:00 PM
Hustler904's Avatar
Hustler904
sounds like the throttle might not be staying open up enough for startup or possilbly gummed up
Old May 22, 2007 | 07:34 PM
silviase7en
hmm how would i go about fixing this? thanks!
Old May 23, 2007 | 01:45 PM
Hustler904's Avatar
Hustler904
try taking the intake tube off and spraying some throttle body cleaner in there while the motors running,you're gonna have to have someone in the car stepping on the gas lightly so the car doesnt choke out,also you're gonna have to keep the intake somewhat connected cause of the maf sensor. Hopefully this helps but cant guarantee anything seeing as how its an electronic throttle.
Old May 24, 2007 | 09:16 AM
Silkk's Avatar
Silkk
1st) Try the ECU Reset/Throttle Relearn procedures available on Technosquare's website
2nd) If that doesn't work, remove and clean your TB, then perform the throttle relearn
3rd) If that doesn't work, try having a dealer or someone with Cipher raise your idle 200rpm
If that doesn't work, you have other options, but not sure you'd want to persue them (drill a 1/8th" hole in the TB butterfly plate to allow a little more air in at idle, etc.).
Do a search for "stall" or "idle" in the title and you will see many people have had this problem and fixed it at little-no cost. Just seems to happen after a few mods; or even just an intake. Mine didn't do it until I had test pipes and reflash performed on my car (after I had all other boltons).
Old May 26, 2007 | 10:10 AM
silviase7en
ok thanks guys, i will try all the things that were listed. i searched and i did not know this was a common problem!! what was it on your car Silkk? i saw your thread..
Old May 27, 2007 | 01:33 AM
silviase7en
finally fixed!!!! first i tried a bottle of lucas injector cleaner and then the technosquare procedures but it wasnt it. then i got some throttle body cleaner and cleaned the throttle body. there was a lot of black buildup and it was it! i only cleaned the outside of the tb since i barely opened the butterfly valve since i was scared cuz it is an Electric-throttle body. can i open it up no problem?
Old May 27, 2007 | 06:37 AM
live2themaxuk's Avatar
live2themaxuk
I disconnected the battery, and then cleaned it all, and yesh, i did move the valve gently up and down to clean it. no worries for me
pslamp32
Feb 8, 2017 09:07 AM
Mattg350z
Oct 2, 2015 06:51 AM
OdesiTT
Sep 30, 2015 10:47 AM
05UltraYellow
Sep 24, 2015 05:41 AM
Darkspy
Sep 7, 2015 09:09 PM
