headlight fuse keeps blowing
Old 07-23-2007, 11:04 AM
dchi_t
dchi_t's Avatar
Default headlight fuse keeps blowing
hey guys, i have an aftermarket HID kit on my car for about 3 years now. just recently i blew a fuse which i didn't see big deal, so i put another of the same rating fuse in, turned on the headlights, and it blew again.
now..the strange thing is, the fuse will not blow if i have the engine on, it only blows when the engine is off.
the picture illustrates how i remembered wiring it.
any ideas why? thanks guys
Old 07-23-2007, 11:58 AM
Ztalker
Ztalker's Avatar
is your retrofit HID kit a direct plug&play unit?
You should not have any problems at all since the factory wiring harness plugs directly into the aftermarket ballast/ignitor. i got mine for over three years trouble free.
Old 07-23-2007, 12:00 PM
HondaKiller
HondaKiller's Avatar
As far is it not popping when the car is on, only when it is off still resorts back to the same thign in my mind. Bad ground wire or corrosion on a power wire. I know its a pain, but time to pull off the wheel well and check for a bad connection on the conversion kit. If that leads to a dead end, try unplugging 1 set of the lights and see which side is popping the fuse. Might need a whole new conversion if problem persist. Let us know what you find.
plessone (11-01-2016)
Old 07-23-2007, 12:03 PM
Paul350Z
Living in 350Z
Paul350Z's Avatar
I'm thinking of a failed ballast grounding.
Do a visual inspection on as much of the wiring as you can to see if something got pinched. The fuse ought to be a ten amp fuse give or take a bit. Make sure if the first fuse was a slo-blow that you replaced it with a slo-blow.
If you can pull the wire for one side from the other that would tell you if one of the two ballasts were bad. If you've got a VOM measure the resistance of each ballast to ground to see if they're different.
Old 07-23-2007, 12:11 PM
Cux350z
hatersgonnahate
Cux350z's Avatar
just through a bigger fuse in there and call it a day!
j/k
dont do that, people really do it but its not safe or recomended. Its burning up due to a short. Youre drawing too much current somewhere.
Old 07-23-2007, 01:14 PM
dchi_t
dchi_t's Avatar
thanks guys, i was thinking of a faulty ground as well. i need to double check it. as far as i can see, the only groud is through the relay, the individual ballasts do not have a ground if i remember correctly. it uses a 20amp fuse.
it is a plug and play unit (i have a base model)
Old 07-24-2007, 07:51 AM
coreapoc
coreapoc's Avatar
No one suggested head light fluid by this point? Surprised.
Old 07-24-2007, 08:06 AM
genesis
genesis's Avatar
your comment did not help the guy at all. He just said that he have a problem.
Uriyo_
09-08-2021 08:46 AM
apex locator
07-23-2021 02:27 AM
Dsowe
02-17-2021 10:38 AM
kyin
10-15-2015 05:54 AM
JGee450
09-30-2015 04:32 AM
Quick Reply: headlight fuse keeps blowing
