clunk from LF
Old Jul 24, 2007 | 07:34 PM
tmak26b's Avatar
tmak26b
Default clunk from LF
whenever i go from stop to go or when i am at slow speed jerking hte car, my LF would produce a clunk. DO you guys have any idea of what it could be?
thanks
Old Jul 24, 2007 | 07:41 PM
03performz's Avatar
03performz
maybe loose sway bar?
Old Jul 25, 2007 | 04:42 AM
HondaKiller's Avatar
HondaKiller
One of the clips might have fallen off your brake pad causing it to shift slightly in the caliber when braking. Atleast that was the case with mine. I had the same clunk, but coming from the rear instead. Need new pads?
Old Jul 25, 2007 | 07:13 PM
tmak26b's Avatar
tmak26b
Pads cant make a clunk like i am experiencing, i am leaning toward sway bars too
Old Jul 25, 2007 | 08:06 PM
03performz's Avatar
03performz
Get your azz under there and check already. Where are you in CT?
Old Jul 26, 2007 | 02:50 PM
tmak26b's Avatar
tmak26b
Bristol
Old Jul 26, 2007 | 02:55 PM
03performz's Avatar
03performz
Bristol
If you were closer I'd take a ride over but your about 75mi. away.
Old Jul 26, 2007 | 05:15 PM
tmak26b's Avatar
tmak26b
The clunk only happens on slow left turns, i am trying to find out more about it. It's hard to do it when my commute is only 3 miles
Old Jul 27, 2007 | 09:11 PM
stalarman@yahoo's Avatar
stalarman@yahoo
tmak, i had the same problem. In my case it was a loose ball joint. Talk to a front end guy at any shop he can have a look and tell you whats wrong. most likely you need to fasten some bolt(s) and it will go away.
Old Jul 28, 2007 | 06:12 AM
tmak26b's Avatar
tmak26b
i briefly played around underneath, didnt see anything loose, but i agree it is something loose. I will bring it to a shop in two weeks once I get my new rear link put in.
Old Jul 28, 2007 | 11:37 AM
stalarman@yahoo
Good luck, give us the results.
Old Jul 28, 2007 | 11:50 AM
Scarab440's Avatar
Scarab440
are there any sounds when you go over small bumps/uneven pavement at 20-40 MPH
Old Jul 28, 2007 | 01:29 PM
stalarman@yahoo
I have that as a matter of fact. Its a bunch of sharp noises. when i turn the wheel it happens to. maybe low on power steering fluid? comes from the left front wheel.
Old Sep 7, 2007 | 09:41 AM
infamous350's Avatar
infamous350
i got the same problem and update on how u fixed it
Old Oct 11, 2009 | 03:52 PM
AARONHL's Avatar
AARONHL
I live in Bristol, CT and have the same clucking noise. Any updates????
Old May 7, 2010 | 07:39 PM
exarmyguy's Avatar
exarmyguy
I'm having the same issues. Whenever I turn left or right at slow speeds I get a clunking/popping noise from the front of the car. Sounds like its coming from right below my feet. I put the car on jack stands and then turned the steering wheel all the way to the left and right. Was able to slightly hear the popping noise, but obviously since there isn't any load on the suspension it wasn't as loud. I also did this while the front sway bar disconnected so I'm pretty sure its a steering component.
Any updates OP? Any other people having similar issues? I also took a look under the car and couldn't see anything abnormal. The noise is driving me crazy!
Old May 7, 2010 | 08:18 PM
Waiz's Avatar
Waiz
Im having the same issue.
Old May 10, 2010 | 07:14 AM
AARONHL's Avatar
AARONHL
I replaced the outer tie rod and the problem is gone!
Old May 13, 2010 | 07:17 PM
exarmyguy's Avatar
exarmyguy
Ok, my situation was a little different then what some people are experiencing in this thread. It was my front Hotchkis sway bar making that popping/clunking noise after all. I have the SPL endlinks, which I lengthened on both sides. I guess before I had them to tight. No more noise!!!
Old May 14, 2010 | 08:21 AM
Brett@AwesomeZ's Avatar
Brett@AwesomeZ
Vendor - Former Vendor
Something loose or a worn bushing in your suspension, the lower control arm bushings on these cars go out pretty often. Need to get it up in the air and get a thorough inspection of your suspension components.
fernandito7
May 3, 2011 08:51 AM
SuperRobin
Aug 23, 2004 08:25 AM
Dissolved
Dec 29, 2003 07:01 AM
failsafe
Oct 16, 2003 09:51 AM
