No prob.. You can also type Function Tuned in the search thingy.. youll find alot of their threads about oil coolers and you could pm them also.. They are really cool approachable peeps..
non-fi, i m just installing the cooler to see if it could cuz less oil burning... i had motul 300v for the last 3 oil changes and normally it burn ~1.5 quarts every 3000km
What year is you r Z? I have about the same oil consumption in mine but I'm FI.
mine's a 03. i found it interesting that the oil cooler get pretty hot (can fry an egg) after 2 mins i started the engine, seems like it does its job. but is this thing gonna cure the oil consumption prob., i am really not sure yet. i m still on the first 300miles after it was put it my z
Those pressures are a little out of line, I would do a Mech chk on the oil pressure first or bite the bullit and shell out 60.00 for a new sending unit ---It will fail eventually anyways, although symptoms are generally a pegged gage.
In Toranto, I guess you almost have to run a thermostat, but that is the only culprit I could see it could be
