clacking sound at cold start up
Old Jul 30, 2007 | 07:31 PM
tmak26b's Avatar
tmak26b
Default clacking sound at cold start up
I get the dreadful clacking sound at the first crack of start up. Is it the oil filter not doing its job or is my oil too thick for the car?
Thanks
Old Jul 30, 2007 | 07:49 PM
mr. sparco's Avatar
mr. sparco
I have the same problem, has happened twice. Sounds like something grinding with the flywheel or something.
Old Jul 30, 2007 | 08:30 PM
tmak26b's Avatar
tmak26b
mine is engine noise
Old Jul 31, 2007 | 05:19 AM
HondaKiller's Avatar
HondaKiller
i think there was a thread about this a week or so ago. From the information i have gathered it has to do with the timing chain chattering on a cold start up do to the lack of oil circulation. The chain is pressurized, and it takes a little to long sometimes for the oil to reach the top of the block. If you search, you can probably find a few different opinions. (i know of Altima's and Maxima's that do this also, i think its a Nissan mishap)
Old Jul 31, 2007 | 07:23 AM
VO...'s Avatar
VO...
Administrator
interesting. This is the 1st I've heard of this problem..
(subscribing)
Old Aug 19, 2007 | 05:00 PM
Full Boost's Avatar
Full Boost
I get the same problem all the time. Especially when the car hasent been driven in a while.
Old Aug 19, 2007 | 05:49 PM
Julian@MRC's Avatar
Julian@MRC
Are you usinf a genuine Nissan OEM oil filter?We found that aftermarket ones tended to allow the oil to blewed out of the timing components.An OEM one helped the issue.Also look into the timing chain tension.
Old Aug 19, 2007 | 06:31 PM
mr. sparco's Avatar
mr. sparco
Nothing but OEM filters here, problem occurs every now and then. Weird.
Old Aug 19, 2007 | 09:20 PM
tmak26b's Avatar
tmak26b
same here, i noticed it for the first time on the 5w40 amsoil. the problem has gone away, but just curious to see if it is the oem filter failing or something
Old Aug 24, 2007 | 06:22 PM
Full Boost's Avatar
Full Boost
Nothing but OEM here as well. I am going to look into it.
Old Aug 24, 2007 | 07:40 PM
Julian@MRC's Avatar
Julian@MRC
What we found was that NON OEM filters,some not all, allowed the oil to drain back out of the timing gears and tensioners while the car sat. The car would clack until oil pressure rose, like 2-3 seconds on ccasion. We used an OEM oil filter, never did it again. But we also switched over to 10-60 oil at the same time.
Old Aug 24, 2007 | 08:15 PM
redman333's Avatar
redman333
This is good info guys, mine has been doing this for awhile, everytime I start up though. I have aftermarket oil filter, not even sure what oil I have in at the moment, GTM did an oil change for me while the car was with them so not sure what I have. Actually they could have replaced the filter as well. I'll have to check tomorrow.
Old Aug 25, 2007 | 05:39 AM
HondaKiller
thats funny, because when i switched over to K&N Oil filters, i thought the clanking stopped on my car. Also switched oils from Valvoline to RP. Might just be my imagination though.
Old Aug 26, 2007 | 08:02 PM
Full Boost's Avatar
Full Boost
I have everything oem and still have the noise at start up. Not sure to be worried or not. It only happens if the car hasnt been driven for a while.
Old Aug 26, 2007 | 08:37 PM
Julian@MRC's Avatar
Julian@MRC
Sound like a faulty timing chain tensioner or cam gear. i would take it back to Nissan and have them fix it. Clacking anytime on a motor is never good.
Obadabot
Jun 18, 2023 11:31 PM
lapham3
Oct 7, 2022 03:15 PM
