Help! My car won't accelerate!
Old Aug 8, 2007 | 08:10 PM
SirSpeedyZ's Avatar
SirSpeedyZ
Default Help! My car won't accelerate!
So here is the situation. Last night I got a flat tire, and its not repairable. No problem right? I order a pair of tires. I have a extra set of rims and the old stock tires, I get them mounted and put them on the car. Go out for a drive and when I try to accelerate at all, the slip light comes on. I can't even gradually accelerate. Everything works fun whenever I turn off VDC, but I'm going on a trip this weekend and I wanted to take a fun car. Please help, I don't know what is wrong.
Front tires: Goodyear Eagle F1 GS-D3 235/50ZR18
Rear tires: Stock Potenzas (225/45R18) I think
All on stock touring rims.
Old Aug 8, 2007 | 08:13 PM
Ztalker's Avatar
Ztalker
you need at least 255/45/18 tires for the rear.
Old Aug 8, 2007 | 08:16 PM
mr. sparco's Avatar
mr. sparco
You practically put RSX tires on a Z. Big no no...
Old Aug 8, 2007 | 08:19 PM
SirSpeedyZ's Avatar
SirSpeedyZ
I had 245/50/18s on there before and it was fine.
I put the ones that came from the factory back on...
Old Aug 8, 2007 | 08:21 PM
deezz's Avatar
deezz
Just turn the VDC off and practice a little throttle control.
Old Aug 8, 2007 | 08:24 PM
easyas1_2_350Z's Avatar
easyas1_2_350Z
If the ratio in tire sizes is off even by the littlest it will trip the computer, throwing the slip light and sapping your car of power.
Old Aug 8, 2007 | 08:28 PM
SirSpeedyZ's Avatar
SirSpeedyZ
I wanna have VDC if I hit rain, as for throttle, I already have enough control, but I like having VDC as added protection.
Damn, I was afraid of that, well at least it is something will be fixed by new tires.
Old Aug 8, 2007 | 08:33 PM
SirSpeedyZ's Avatar
SirSpeedyZ
what if I switch the front and rear tires?
Old Aug 8, 2007 | 08:34 PM
mr. sparco's Avatar
mr. sparco
Are you sure your factory tires in the REAR were 225s.
Old Aug 8, 2007 | 08:36 PM
SirSpeedyZ's Avatar
SirSpeedyZ
come to think about it, they might be the stock front tires, damn.
Old Aug 8, 2007 | 08:40 PM
SirSpeedyZ's Avatar
SirSpeedyZ
if I switch the front tires to the rear would that fix the problem?
how could I do this without a lift?
Old Aug 8, 2007 | 09:50 PM
Ztalker's Avatar
Ztalker
yeah put those back in the front and 275/40/18 for the rear.
Old Aug 9, 2007 | 12:20 AM
03Platinum350z's Avatar
03Platinum350z
Im rocking stock Potenza's on mine (235/50r17), their ok but you have to special order them because no one stock's em....I just found that out when I blew a rear a week back But i got her back today!!
Jeff
Old Aug 9, 2007 | 12:40 AM
Zian's Avatar
Zian
use a jack and jackstands if you don't have a lift. and make sure to torque the lugs the proper amount. tho if you have to ask that...it might be good to get some help :-)
Old Aug 9, 2007 | 03:31 AM
6SPD Z33's Avatar
6SPD Z33
one side at a time yo.....
Old Aug 9, 2007 | 04:35 AM
SOLO-350Z's Avatar
SOLO-350Z
'12 TL SH-AWD
225 is not factory size rubber.
Old Aug 9, 2007 | 05:38 AM
SirSpeedyZ's Avatar
SirSpeedyZ
^^^ those are the tires that came with the stock rims, I'm guessing the previous owner didn't buy smaller tires, idk.
ok, I'll switch them this afternoon, but now when I'm driving (VDC off) the ABS and Brake lights come on, WTF? my car is going crazy!
Old Aug 9, 2007 | 05:43 AM
raycs7's Avatar
raycs7
It is ... for the fronts.
switch front and rears..
Old Aug 9, 2007 | 05:50 AM
SirSpeedyZ's Avatar
SirSpeedyZ
^^^ that is what I thought, I already said I thought they were the fronts
anyone know about the other problem? anyone else ever have that happen?
Old Aug 9, 2007 | 05:54 AM
SOLO-350Z's Avatar
SOLO-350Z
'12 TL SH-AWD
That is because they sense the tires/wheels are off. My G35 did it on the dyno. You need to get the right size tires on the car. Even if you just move them to the front the car will still freak out because the tires are too far off from each other.
