Help ECU+VDC+Brake+Battery light are all on!
Old Sep 4, 2007 | 04:07 PM
k1prototype's Avatar
k1prototype
Default Help ECU+VDC+Brake+Battery light are all on!
I was wondering if someone could give me some advise on what might be going on.
I have a 2003 Touring Z w/ no mods.
I was driving to work today and all of sudden out of the blue, my battery and hand brake light came on. This was followed by the Slip and VDC lights as well. Next thing I know the car has no power and I can only go 5 mph. Periodically its as if the ecu resets (all of the lights go off) and it will let me get up to 8-10 mph before kicking in again (all the lights coming on).
In addition the battery meter was off the charts!
So I figured i'd try to turn the heat on because that usually helps cool a car down considering its 90 degree's outside. However the temperature gauge was at normal operating temperature.
Doing this solved the problem and I was able to drive back. The lights went away and the battery gauge was back to normal. However as soon as I turned the air off the problem came back.
I stopped and checked the engine to see if something was overheating and nothing looked like it was. My coolant resvoir tank seems about 1/2 filled as well.
So my question is does anybody know wtf is going on w/ my car???
Old Sep 4, 2007 | 08:09 PM
fklentz's Avatar
fklentz
Do you have a check engine light on? Your car went into "Limp" mode, in that mode the ECU senses a problem and gives just enough power to get off the road to a safe spot. If you can get a code scanner the ecu should have some freexe data as to why it did this.
Old Sep 4, 2007 | 10:36 PM
kihun's Avatar
kihun
that **** happened to me.. i shut my car for a while and i started and it went away.. grr
Old Sep 5, 2007 | 06:11 AM
infamous350's Avatar
infamous350
that happened to me no engine light though but slip light vdc and my brak fluid was low i added some and never had the problem again
Old Sep 22, 2007 | 06:53 PM
JRHollywood's Avatar
JRHollywood
Its been happening to me for a week.. VDC Off, Brake, and Slip lights are all on, always. It's a pain in the ***. The brake one goes on and off... if it goes off and I have to brake hard it comes back on. I assumed a wire was loose or fuse blown?
loudtoyz
Apr 6, 2023 04:52 AM
Uriyo_
Sep 8, 2021 08:46 AM
350z82
Oct 1, 2015 06:25 PM
Sleeper_Z
Sep 30, 2015 10:25 AM
samansharif
Sep 25, 2015 12:31 PM
