Indicator Light Threats
Old Sep 11, 2007 | 03:30 PM
Eazzy's Avatar
Eazzy
Question Indicator Light Threats
Driving back from town this morning and at some point in time, the ABS,TCS (OFF) and the SLIP Lights came on. I generally drive with the TCS turned off but dont recall if I was...Probably.
Im showing no codes in Cold Idle, Hot Idle or Driving Mode. I cleared anyways and they remain----Brakes are fine, Idle is good, General driving is normal. Has me annoyed. Anyone have Input ?
Old Sep 12, 2007 | 09:06 PM
Eazzy's Avatar
Eazzy
Bump ----They Cleared but still like some input
Old Sep 19, 2007 | 06:04 AM
Eazzy's Avatar
Eazzy
Did it again -----Perplexed----cleared
Old Sep 19, 2007 | 07:28 AM
Tim@WestCovinaNissan's Avatar
Have you put new tires on the vehicle or had any other repair work done??
Old Sep 19, 2007 | 07:32 AM
Eazzy's Avatar
Eazzy
No ---I own a shop myself ---Nothing is changed, It annoys me a little but its not life threatning, just curious---guess I will check pad thickness. Comes and goes, no rhyme or reason I can see yet. Just there a day or 2 and then clears
Old Sep 19, 2007 | 07:36 AM
Most likely one of three things....either the steering angle is not calibrated correctly, possible bad abs sensor or one of the abs rings may be damaged. Maybe none of those but definate possiblities.
Old Sep 19, 2007 | 08:29 AM
project.dwnshft's Avatar
project.dwnshft
easy ive been getting the exact same thing for the past few weeks....i noticed it when i would get on it in 1st gear all 3 lights would come on and stay on and the brake light would eventually go away but the other 2 would stay on and id have to let the car sit off for while then turn it back on and the lights r gone. i did recently install a popcharger and the first time i started the car after install these 3 lights came on so i just turned the car off and restarted and they went away. i have also recently put new tires on the car cause the stock ones were bald and loosing air. I also get the low tire light after driving the car for about an hour, it was doing this before and after the new tire install, nissan wanted 90bucks to dismount the tires and check the sensors that i can see are noit working cause the monitor doesnt and has never read any tire pressure
Old Sep 22, 2007 | 11:33 PM
Eazzy's Avatar
Eazzy
Interesting ---I havent been getting notifications there has been responses here---Course I dont have Pressure sensors and as I said --Im getting no Codes---Tires are good as is Align---Comes and goes. Like I said, Im not losing sleep, but just wonder what is going on in that mind, mounted above the right kick panel (ECM)
loudtoyz
Apr 6, 2023 04:52 AM
Uriyo_
Sep 8, 2021 08:46 AM
350z82
Oct 1, 2015 06:25 PM
Depravity
Oct 1, 2015 04:49 PM
samansharif
Sep 25, 2015 12:31 PM
