Idle noise
Old Mar 9, 2008 | 08:02 AM
Corradoslc7's Avatar
Corradoslc7
I'm sure it's more expensive for any auto manufacturer to equip a car with a DMF compared to solid flywheel. Most car companies are using DMF's today so compared to other cars, Nissan's DMF is probably equally priced.
Old Mar 9, 2008 | 10:09 AM
ladyzed's Avatar
ladyzed
Thanks
Old Mar 10, 2008 | 08:04 AM
buckeyeZ's Avatar
buckeyeZ
yea they are more expensive than regualr flywheels.....my tiburon had a dual mass flywheel on it stock and my clutch failed on it....was going to be like 800 bucks just for another stock flywheel.....so i went with ACT.....stage 2 kit(flywheel, TOB, Clutch disk) for only 450
Old Apr 6, 2008 | 05:39 AM
Bananas!'s Avatar
Bananas!
I don't get it,
I've had manual transmission cars all my life. Changed more than a few clutches,transmissions, flywheels, etc. I've never seen a drive train thay makes the racket that these Z's make. As far as a solid flywheel making more noise than this dual mass junk, why is that? I've never had a dual mass flywheel before but, of the solids that I've had, not one ever made a sound. Occasionally when a throwout bearing went bad and was noisy, that meant that it was time to change it.
As far as these lousy transmissions are concerned, somebody needs to make an adapter kit to couple up a t-6 to the Z's 3.5.
Bananas!
Old Apr 7, 2008 | 02:32 PM
Z Infidel's Avatar
Z Infidel
I have this same issue but you have all covered it so well I have nothing to say but this, thanks!
Old Jul 2, 2008 | 10:35 AM
NewZ84's Avatar
NewZ84
return of the thread....
quick questions. anyone know if the dealership will replace the clutch/flywheel due to this noise and will it be covered under the 60K mile drivetrain warranty???
Old Jul 2, 2008 | 12:05 PM
sharples2's Avatar
sharples2
Originally Posted by toy4two
I'll take these differences if it means having to hear a faint noise at idle with the clutch out, the only time I can really hear it is sitting in a drive thru and have my window down while it bounces off the fast food building.
Soo true. That is the only time I hear it when I get my coffee in the morning at DD.
Old Mar 11, 2010 | 12:22 AM
orangeflash's Avatar
orangeflash
wow, I havent checked this thread in a while. Still have the problem. Never really looking into it. Ohh well, im sure i need a new clutch soon.
Old Mar 11, 2010 | 08:55 AM
ZKansasZ's Avatar
ZKansasZ
change the clutch will solve the sound problem, the end.
Old Mar 19, 2010 | 02:46 PM
BJJ Gi Choke's Avatar
BJJ Gi Choke
yep mine does it too, its normal for these cars. Nothing to be worried about, doesn't effect reliability in the least. These cars have carbon drive shafts, dual mass flywheels, many things you won't find in your regular old car, there is going to be differences, personally I'll take these differences if it means having to hear a faint noise at idle with the clutch out, the only time I can really hear it is sitting in a drive thru and have my window down while it bounces off the fast food building.
Always does this when I'm next to a wall.
Obadabot
Jun 18, 2023 11:31 PM
liqalu04
Jan 2, 2022 12:58 PM
hulkout
Tuning
Sep 30, 2015 12:33 PM
