Nissan dealer look at this:Just curious
Old Oct 8, 2007 | 08:32 AM
SvR350z's Avatar
SvR350z
Default Nissan dealer look at this:Just curious
Hey,
I took my car to nissan dealership today. They said the throttle body was messed up and they would replace it under warrarnty. No problem.
I ask them to look at my head lamps. They are so fogged up its insane.
They said no problem, We waxed them and they come clean. I call bs.
I wax my car monthly. It wouldnt come off with normal wax. Isnt there a bulletin on this issue? If so, link me? Seems like to me they should replace those junkers.
Lastly, Breaks were making god awful noise. Says i need new front pads
and new front rotors. 20k miles on the car and i baby the thing.
Keep in mind my tires have had to be replaced already too.
Just wondering if im getting ripped. Thanks
Old Oct 8, 2007 | 08:34 AM
TacoMadre's Avatar
TacoMadre
What year is your Z?
Old Oct 8, 2007 | 08:52 AM
Brrcats's Avatar
Brrcats
If you're brakes are making a god awful noise you probably have wore down your pads to the point of scoring your rotors, thats something you should have heard coming.
Dont know about the rest
Old Oct 8, 2007 | 09:29 AM
SvR350z's Avatar
SvR350z
My Z is a 2004. Yes, I knew there was a problem when i heard the noise thats why i took it in. The noise was there for a week or less but that was the quickest they said they could look at the car.
They are now telling me that nismo doesnt make brake pads for my car.
It is a base but I thought that they made non brembo nismo brake pads for the 350z. The guy ask me if my z was a nismo z. I was like no it just has nismo parts and he is like then you cant use nismo brakes.
Old Oct 8, 2007 | 09:34 AM
Ztalker's Avatar
Ztalker
at 20k miles....yup, your oem brakes are overdue for replacement.
cheshirecat79's Avatar
cheshirecat79
depending on the "fog" on your headlights, it may just be exterior plastic and not internal. there have been quite a few threads about cleaning the headlights in this manner. if you have condensation on the inside of the headlight, that's a different issue.
your normal oem brakes use normal oem brake pads. don't worry about "nismo brakes".
Old Oct 8, 2007 | 10:22 AM
I cant tell a thing about the rotors unless I measure them. How thick are they?
Old Oct 8, 2007 | 01:54 PM
SvR350z's Avatar
SvR350z
David, The nissan stealership said they were supposed to be like 25mm and are 23 or something like that.
Old Oct 8, 2007 | 01:56 PM
LouiZ's Avatar
LouiZ
i have 30k miles on my car and have yet to replace my brakes...they have plenty of life left u guys must b some hardcore brakers
Old Oct 8, 2007 | 03:16 PM
SvR350z's Avatar
SvR350z
Im not a hard braker at all. Thats why im asking these questions. I havent even spun the tires on my Z since ive had it. I treat that car like its a baby.
It gets only the best treatment which is why i nearly pissed myself when the dealer said the brakes and rotors were shot.
I dont mind replacing the brakes. I want something with a low dust compound anyways. The rotors though, That blows.
Old Oct 8, 2007 | 04:09 PM
BRONZEE's Avatar
BRONZEE
Club Moderator
Also depends if it's MT or AT (and if you use manual mode).
Old Oct 8, 2007 | 04:38 PM
Tim@WestCovinaNissan's Avatar
Needing brakes at that mileage is not uncommon. The rotors on the Z's do wear out early. 80% of Z's with over 18k on them need the rotors replaced....they wear too thin and develop too big of a lip on the edge to resurface. Each case is different. I've had people hard on their brakes not have to replace them till 30k, others that are soft on the pedal had to replace them at 13k. If you want pads with less dust try the Hawk HPS pads, low dust and noise. However, if you put new stock rotors on with hard pads, expect to replace your rotors even sooner next time. Look into some different rotors, most are no more expensive that the stocks.
Old Oct 8, 2007 | 05:39 PM
SvR350z's Avatar
SvR350z
Tim,
Thank you much. Can you tell me if i can use non brembo nismo pads?
The dealership here in town said you cant. I think it can be done.
Id like to get those if possible.
Old Oct 9, 2007 | 08:50 AM
Yes you can. About $140.00 for the pads.
Old Oct 9, 2007 | 08:54 AM
SvR350z's Avatar
SvR350z
Tim has pm
07ZEKE
Aug 23, 2021 09:15 PM
sales@czp
Sep 23, 2019 03:30 PM
ablaine
Nov 29, 2016 10:13 AM
EnjukuRacing
Sep 30, 2015 06:55 AM
