Differential Noise?
Old Oct 12, 2007 | 05:34 PM
350ZREDLINE's Avatar
350ZREDLINE
Default Differential Noise?
Ever since I replaced my LSD oil with mobil 1 I have had this ERRRRRRRRRR noise in the rear when I accelerate (no its not the normal exhaust noise, its a very weird noise).
I heard that you dont need LSD additives because the LSD part is sealed etc. So what would cause this noise???? Is mobil 1 a bad oil to use in the differential? Should I replace it with something else? Or do I need a LSD additive for some strange reason?? Or could mobil 1 having LSD additive cause the problem??
Thanks for any advice
Old Oct 12, 2007 | 05:58 PM
Ztalker's Avatar
Ztalker
was the noise there before the oil change? i would replace it with nissan oem oil or whatever the spec indicates.
Old Oct 12, 2007 | 06:02 PM
350ZREDLINE
no it wasnt.... I went to nissan dealership and they pulled out pennzoil 80w90...... I guess I could put non synthetic in there, but I figured synthetic would be better.
Old Oct 12, 2007 | 06:24 PM
blastoff99's Avatar
blastoff99
I assume you used the M1 LS 75W-90? The write-up I found says it's ok for LSDs. But from your description it sounds like something isn't happy.
Old Oct 12, 2007 | 06:45 PM
350ZREDLINE
Ya 75W-90 is what I used....... Maybe I should switch to a non synthetic or maybe try some LSD additive for the heck of it????
Old Oct 12, 2007 | 07:29 PM
blastoff99's Avatar
blastoff99
You didn't overfill it, did you?
Car should have been level (on four jack stands or a lift) when you filled it.
Old Oct 12, 2007 | 08:04 PM
350ZREDLINE
well i was lazy, I only lifted one side of the rear, drained and then filled it, but then I put the car flat on the ground and let the excess oil flow out. So it shouldnt be over filled
Old Oct 12, 2007 | 09:22 PM
Ztalker's Avatar
Ztalker
i changed mine with a hand pump earlier this year with a synthetic blend/ oem weight(generic brand). No issues whatsoever.
Old Oct 13, 2007 | 05:59 AM
blastoff99's Avatar
blastoff99
Well, there goes my theory.
Here's what I'd do: Go to the dealer and buy from them whatever fluid they'd put in the car. If they don't have any to sell you, ask them exactly what they use, and go buy it at your friendly parts store. Swap out the fluid, and see if you still have the noise. If you do, make an appointment for ASAP at the service department. Keep your receipt for the last fluid purchase. Good luck, and I'll be curious to know what the outcome is.
Old Oct 13, 2007 | 01:41 PM
350ZREDLINE
I went to O'Reillys Auto parts (were i bought the mobil 1 gear oil) and told them my situation to see if they had any recommendations (figured why not). They said they never heard of any problems with mobil 1 gear oil, and said its one of the best on the market. They mentioned royal purple being good to, and then I asked if they had any. They had to go back to the back to see if they had any, and they came back with there last 2 quarts. I asked them how much, and they said free (WOOHOO). So i will be putting that in later and seeing if it fixes the problem..
Old Oct 13, 2007 | 01:45 PM
Jay'Z's Avatar
Jay'Z
Does the noise get louder as you speed up?? Does it sound like rattling??
Old Oct 13, 2007 | 03:06 PM
350ZREDLINE
no its not a rattle, its more of a hollow ERRRRRR noise....
Old Oct 17, 2007 | 09:36 AM
350ZREDLINE
O'Reillys gave me Royal Purple 75W-140, I have read that thicker protects better (in diffs) but will give worse gas mileage. I didn't care about the small gas mileage decrease so I put it in, so far I haven't heard any weird noises from the rear since. It has fixed the problem, at least as far as i can tell. Maybe I just needed a thicker oil, or maybe Mobil 1 75W90 isn't very good
Obadabot
Jun 18, 2023 11:31 PM
wanderingstuden
Jan 28, 2016 07:03 PM
hulkout
Tuning
Sep 30, 2015 12:33 PM
samansharif
Sep 25, 2015 12:31 PM
