Sputtering During Warm-up
Old Feb 9, 2008 | 01:34 PM
  #121
stylett9's Avatar
stylett9
Originally Posted by itsjiggajames
That sucks. Hope you get it resolved. But do you know the cause of why after installing HFCs I get that too? A/f sensor going crazy?
it depends. Do you have a check engine light? If you are experiancing the one that i had which happened between 2500-2800 RPM's, the engine would basically bog and choke, and you had to accelerate slowly to get out of that range. I fixed this by replacing my 02 sensor on the headers. But i had a CEL which i knew meant my 02 was bad and causing the problem.
But if you are referring to where right when you step on it, the car stutters for a SPLIT second, i dont think there is a fix for that. That's just normal and i'm not sure of the cause of that.
Old Feb 14, 2008 | 07:38 PM
  #122
stylett9's Avatar
stylett9
update: everything is stock, replaced air/fuel sensors and problem still not fixed. Guess we are back to square 1
Old Mar 7, 2008 | 02:21 PM
  #123
stylett9's Avatar
stylett9
So after dealing with Nissan consumer affairs for the past 3-4 weeks, and being handed off to 3 different regional specialists, their solution today was "bring your car back to the dealer and have them call Nissan Tech line"
4 WEEKS!!!!!!!!!! of "we are trying to get in touch with the dealer and we'll get back to you"
today they have the nerve to call me and say "ok go ahead and bring the car back to the dealer"
GAAAAARRRRRRRRRRRRRRRR!!!!!!!!!!!
Old Mar 21, 2008 | 10:43 AM
  #124
zwarbyt's Avatar
zwarbyt
any updates here?
Old Mar 23, 2008 | 06:38 AM
  #125
Tac-M's Avatar
Tac-M
hot dawg... mine is doing it....
Old Mar 23, 2008 | 08:43 AM
  #126
mw9's Avatar
mw9
Here is the thread I started awhile ago. Alittle more info, threw a bunch of codes. A couple posts down
https://my350z.com/forum/maintenance-and-repair/326876-problem-between-2000-2500-rpms.html
Old Mar 23, 2008 | 10:13 AM
  #127
mw9's Avatar
mw9
Just went out and logged about 30mins of data. Couldn't get the car to act up.
Old Mar 24, 2008 | 10:28 AM
  #128
stylett9's Avatar
stylett9
I don't believe you are experiancing the same problem. Your car is having problems accelerating which could be at fault of a bad 02 sensor or various other reasons.
Our cars are accelerating just fine but it feels like your riding in a bus with a bad driver. (very shakey and choppy)
anyways, i'm done of trying ot deal with this problem. I experiance it 3 times a day and i've taken it to the dealership 4 times and they can't diagnose the same problem.(bad luck i guess...sigh)
Old Mar 24, 2008 | 11:18 AM
  #129
tourinz's Avatar
tourinz
Mw 9 What Year Is Your Car?
Old Mar 24, 2008 | 11:20 AM
  #130
tourinz's Avatar
tourinz
Guys, My Car Is Acting Up Too... I Have Logged My Car While Happening, Send The Data Sheet To Nisssan Technical Support And They've Been Talking About Oil Weights... I Had 10-30 And I Changed It To 5-30... Also This Problem Did Not Happen While Using Octane 100 But As Soon As I Go Back To Straight 93 (w/o Octane Booster) The Problem Comes Right Back CAN EVERYONE PITCH IN ON THE GAS/ OIL WEIGHT THEY'RE USING?
Old Mar 24, 2008 | 01:41 PM
  #131
Tac-M's Avatar
Tac-M
10W40 here and 93 shell
Old Mar 24, 2008 | 02:20 PM
  #132
capnstabn's Avatar
capnstabn
5w 30 and 93 whatever.
Old Mar 24, 2008 | 04:24 PM
  #133
mw9's Avatar
mw9
2003 with 5w-30 amsoil
Old Mar 24, 2008 | 10:13 PM
  #134
stylett9's Avatar
stylett9
i dont know my oil exactly but i know i've switched between motul and mobile 1 full synth. I've also switched between various brands of 91 octane fuel(93 not available in cali, that i've found)
Old Mar 25, 2008 | 05:10 AM
  #135
07JimmyZ's Avatar
07JimmyZ
5W30 and 93 mostly shell whenever possible. if you need another car to test I'm in the area as well, although I have HFC's.
Old Mar 25, 2008 | 07:37 AM
  #136
tourinz's Avatar
tourinz
well, it seems that we are all using the same problem... techline has another 12 cases open in the nation, but the problem is it only happens before the vehicle reaches proper operating temperatures, so it's a guessing game for what i can see...I got two guys trying to crack this, (w/ the help from nissan) so, let's see how it goes...
Old Mar 25, 2008 | 05:06 PM
  #137
stylett9's Avatar
stylett9
goodluck. I hope we have a solution before my warrenty is up.
Old Mar 28, 2008 | 02:25 PM
  #138
Tac-M's Avatar
Tac-M
TT for updates....
Old Mar 29, 2008 | 09:32 AM
  #139
stylett9's Avatar
stylett9
tourinz, please let us know at the first sign of any update. My friend, who is a mercedes benz service writter gave me a pretty good theory about how it might be an uneven pressure plate in the transmission or something like that. Said that as the transmission heats up(which would explain why its a very predictable time from a cold start) the pressure plate metal will expand and if it's uneven or something like that it oculd be the problem. I've taken his theory into consideration and so everytime the "sputtering" kicks in, I feather first gear, and unless i'm just imagining it, it does seem that the problem goes away faster. The only reason why i don't think it's something in the transmission is because the exhaust sound changes.
Old Mar 29, 2008 | 01:52 PM
  #140
Tac-M's Avatar
Tac-M
^ that sound change in exhaust is what concerns me the most. this problem could be related to our variable valves .
