Build date associated with problems? [post here]
Old May 30, 2003 | 05:08 PM
synth19's Avatar
synth19
Default Build date associated with problems? [post here]
I did a search on this and I'm suprised no one has tried to associate problems with their Z to your build date. I'm trying to see if there is a trend from later built '03 Z's to the first ones....So far no problems, even though I've had my Z for only a week...
Production Date: March/'03
Problems: None so Far.
What about the rest of you guys?
Old May 31, 2003 | 07:51 AM
TCL's Avatar
TCL
Build date July 2002
- Window grease streak
Old May 31, 2003 | 09:06 AM
Stone Z's Avatar
Stone Z
Build Date:
1/03
Problems:
Window grease
*Very* slight pull to the right
Slightly misaligned steering wheel
Old May 31, 2003 | 05:12 PM
MikeW's Avatar
MikeW
Build Date: Jan. 2003
Problems: None
Old May 31, 2003 | 06:09 PM
westpak's Avatar
westpak
SFZCC
July 02
Window streak
Front tire feathering
Rear axle noise
Valve cover leak
Seat movement
Front control arms clunk
Visor rattle
Old Jun 3, 2003 | 07:19 PM
themyst's Avatar
themyst
July 02 Vin#957
Steering rack&pinion failed
Steering pump contaminated
tire feathering (only the right wheel feathers)
new transmission (3rd gear grind... then 4th and 5th started grinding too)
window streaks (minor)
fuel won't fill to the top (happened once or twice)
What problems DONT I have?
Bouncy ride (feels more planted than my 01 celica GT)
clicking seat
Old Jun 3, 2003 | 07:26 PM
Drumtemp's Avatar
Drumtemp
Originally posted by Stone Z
Build Date:
1/03
Problems:
Window grease
Hmmm, I think I'm with you on 2 outta 3:
PLUS: possible seat clicking
Build date: 2/03.
Just as a comparison: My 1990 240SX--second year build--had the following problems:
Paint mismatch on rear side panel (found it after I brought the car home from dealer)--dealer repainted side.
Tach went out 2 days after purchase: dealer replaced tach.
During test drive to check tach (by service man) a rock hit the front windshield and cracked it: dealer replaced windshield.
All this just within the first week!
Old Jun 3, 2003 | 07:30 PM
n8vz's Avatar
n8vz
CS Track
Build date: April 03
Problems:
squeaky brake at low speed (normal for brembo?)
nothing else.
Old Jun 4, 2003 | 04:12 AM
ZpikeZ's Avatar
ZpikeZ
Build date 1/03
Problems:
Grease streaks (is that a problem?)
Front seat clicking
Old Jun 4, 2003 | 05:04 AM
Blue Liquid's Avatar
Blue Liquid
The Brembo's come with a higher friction pad than standard brakes. It is completely normal for them to squeal a little bit at low speeds. The noise is a trade off for higher initial bite and greater fade resistance.
Old Jun 4, 2003 | 05:45 AM
kbsig106's Avatar
kbsig106
Default Build Date
Build Date: 12/02
Problems:
1) Grease streak on both windows
2) Very slight pull to the right (might even be the road)
That's about it - ohh and a few paint chips.
Old Jun 4, 2003 | 08:22 AM
WashUJon's Avatar
WashUJon
Grease on driver's window (doesn't even bother me)
Tiny bit of orange peel (I wouldn't even call it a problem, but some do)
Slight pull to the right, steering wheel slightly off-center (I bet it just needs an alignment)
Tranny has hard 2nd gear shifts when gear oil is cold (its actually improved with mileage, so I'm waiting)
There was a dash rattle but it went away mysteriously
Tons of brake dust (not a problem but a PITA and still easily fixed)
No signs of tire feathering yet at 2800 miles.
Uriyo_
Sep 8, 2021 08:46 AM
