Strange Vibration
Old Nov 12, 2007 | 07:50 PM
bremboboy's Avatar
bremboboy
Default Strange Vibration
For the last few days, I have noticed that whenever i start up the car for the first time, put it in first, and drive away, i hear this strange vibration coming from the right front wheel area when ive just let up on the clutch and am going maybe 3 miles per hour...it sounds like im going over a metal gate and it lasts for maybe two seconds and then it goes away, but the sound is just coming from the right front wheel area. I can't seem to repilcate the problem by stopping and moving again...ive only noticed it the first time I move after I start up the car. 2006 z no wheel/suspension mods.
What do youthink this is?
-thanks!
Old Nov 12, 2007 | 07:59 PM
Chef-J's Avatar
Chef-J
Booooosstt!!
take it to dealer if you still got warranty.
you could get damaged on front side ( mayb went over something )
Old Nov 13, 2007 | 04:59 AM
bremboboy's Avatar
bremboboy
its hard to replicate the problem...
Old Nov 13, 2007 | 06:06 AM
cheshirecat79's Avatar
cheshirecat79
The ABS will do a self-test once you start rolling past a couple of miles an hour. It should do it every time you start the car. However, it doesn't sound like that at all.
The sound you're describing does sound like the ABS system in action but it's definitely not normal.
Old Nov 13, 2007 | 09:32 AM
bremboboy's Avatar
bremboboy
thanks for your help
Old Nov 13, 2007 | 10:45 AM
DJMatrix1067's Avatar
DJMatrix1067
ABS for sure.
did you feel anything in the pedal when it does it? How about any lights on the dash? Double check your brake fluid too. I would get this professionally checked out, it could be hazardous.
Old Nov 13, 2007 | 06:43 PM
bremboboy's Avatar
bremboboy
i guess i really wasn't paying attention to the pedal when I heard the sound. As for the lights on the dash, I'm pretty sure there weren't any but ill double check all of this stuff and the brake fluid when I take out the car again. Ill update shortly... thanks!
Old Nov 13, 2007 | 06:48 PM
kacz07's Avatar
kacz07
i have the same problem...i can feel it when my foot is on the gas pedal...i have an 06 too...i noticed it after i went over a hard bump...but it could have been like that before not sure...happen when i turn left or right..just the first time i start up tho
Old Nov 15, 2007 | 09:03 PM
bremboboy's Avatar
bremboboy
I just checked my brake fluids and they are normal (just a tad bit below the Full line). Everytime I start the car and drive away the first time it makes the strange vibration. If its the abs what exactly would be the problem with it?
Old Nov 16, 2007 | 05:55 AM
cheshirecat79
If it does it every time and isn't an intermittent problem, take it to the dealer. Don't waste your time trying to solve an issue that's not common.
Old Nov 16, 2007 | 06:30 AM
bremboboy's Avatar
bremboboy
ill take it this weekend...thanks
Old Nov 16, 2007 | 08:07 AM
cheshirecat79
Be sure to let us know what the issue ends up being.
Old Nov 21, 2007 | 08:31 PM
bremboboy's Avatar
bremboboy
dealer said the sound is normal from the abs system...
the tech said that the 06+ abs system is more advanced than the previous years?
I personally dont think it should make an audible sound...any 06+ owners hear this sound?
Old Nov 22, 2007 | 05:49 AM
DavesZ#3's Avatar
DavesZ#3
The ABS test is definitely loud enough to hear and strong enough to feel in the pedal. It may seem to be intermittent or random because you don't always notice it, I only notice it 50% of the time in the early morning. It depends on how long you let the car sit and idle, if and when you tap the brake, how fast you're moving, etc.
Old Nov 22, 2007 | 06:59 AM
cheshirecat79
I can hear and feel my ABS test in the morning, but it doesn't feel like I'm going over a sewer grate. From what you described it sounded more than your average ABS test.
However on startup it does it every time as you start moving, so having the ABS come on is completely normal.
Old Nov 26, 2007 | 11:10 PM
kacz07's Avatar
kacz07
yeah they did tinker with the OEM non brembos
awesome...thats comforting...today it was a misty out so it sounded a little different cuz of the condensation...this has been helpful...thanks
Old Jun 2, 2008 | 06:03 AM
ekiely's Avatar
ekiely
I have the same problem with my 07. The dealer couldn't diagnose the problem so they called the Nissan Tech line who said it was the ABS “resetting” and was normal. I questioned this because the noise didn't start when I first bought the car. I probably started hearing it after 6 or 8 months. It happens whenever the car has been parked for 10 minutes or more. Have you been hearing it since day one?
Old Jun 2, 2008 | 08:51 AM
jray8's Avatar
jray8
i had the same problem on my 03 it was just the rear brake pads shifting when i started from a stop hasn't happened in 4 months now
Old Jun 20, 2008 | 11:21 AM
sir captian's Avatar
sir captian
Yep I have a Base 2006.5 and it does it every time .
lapham3
Oct 7, 2022 03:15 PM
AbyteZero
Sep 22, 2015 09:17 AM
Bigsyke
Sep 11, 2015 06:19 PM
Chebosto
Jan 17, 2003 11:59 PM
z350z
Dec 16, 2002 05:54 PM
