I DRILLED HOLES in My GAS TANK
on
Ok, so About 2 years ago I put a car audio system in my Car, I had 2 amps that I placed in the area behind the seats, 1 were the glove compartment is and 1 where the factory sub was. I decided to screw them in place by using self tapping screws to screw into the floor. Anyway when I installed the stero my service engine soon light went, I assumed it was jsut becasue the car didnt light all the amperage the stero was pulling and figured it was fine and would go off when I took my stero out. fast foward two years, of driving with the light on, and with having no problems ever with the car. I took my stero out, I got in my car the next day and my car was full of a gas smell. Apparently some of the screws I screwed in pierced my gas tank, the screws plugged the leak so the smell couldnt get through but when the stero came out the holes were open. I put the screws back in place and it stopped the smell, but my service engine light is still on, I checked the code and it showed code 0455, which is a EVAP GROSS LEAK. Any Ideas how to fix the problem, like replacing the tank or sealing it, or just disabling the code, since it does drive fine. Thanks
Ryan
Ryan
![](https://my350z.com/forum/images/ranks/premier.gif)
on
good lord.........self tapping screws........your supposed to be sure of whats on the other side before you use those things..
I would assume that a heavy duty eppoxy would seal it up, im guessing they were small holes. do that then reset the computer and see if the light comes back on.
- j
- j
liqalu04
01-02-2022 12:58 PM
11-09-2020 10:27 AM
350Z_Al
10-29-2020 07:44 PM
