i need help, installed test pipes an they smoke
Old Jan 1, 2008 | 09:17 AM
surfer05rdr's Avatar
surfer05rdr
Default i need help, installed test pipes an they smoke
i recently installed some jvt racing test pipes on my 03 Z and its sounds good plenty of power but after 30 mins of driving they start to throw out white smoke real bad. Does anyone know what it could be?
Old Jan 1, 2008 | 09:21 AM
djclongisland's Avatar
djclongisland
hmm well i has alot of white smoke the other night, but it was just the cold weather, theres less restriction on your exhaust so it is comeing out the rear faster,
Old Jan 1, 2008 | 09:31 AM
surfer05rdr
the smoke has a strong smell almost like a burning smell but after i start it i can drive for about 30 mins and it doesnt smoke at all but then when i slow down or come to a stop it throws out a thick cloud of white smoke....
SuperBlack350z's Avatar
SuperBlack350z
how many miles is on your z?
Old Jan 1, 2008 | 09:57 AM
surfer05rdr
it just turned 60K yesterday but the car never smoked at all when i had the cats on it but as soon as i put the test pipes on it is when it started,
Old Jan 1, 2008 | 11:02 AM
Test pipes do not make smoke. The pipes are not the cause of the smoke.
Mark the coolant level. You may be burning coolant in the combustion chamber.
Fouled fuel injectors will also result in pillows of white smoke.
Old Jan 1, 2008 | 02:56 PM
surfer05rdr
how would i check the fuel injectors to see if they are any good or would i have to take it somewhere to have that done
Old Jan 1, 2008 | 04:46 PM
MDeezy's Avatar
MDeezy
if there is a shop close by to you that can flow test your injectors try that.
the injectors are easy to remove, inspect the o-rings.
Its odd for your car to start smoking like this after you installed the test pipes, but as already stated the test pipes wouldn't cause the smoke.
what color smoke is it?
power loss?
any codes?
if needed do a compression test.
Old Jan 2, 2008 | 02:23 PM
surfer05rdr
the color of the smoke is white and there is absoutley no power it feels to have gain alot of power and my check engine light never came on which i have a friend with a 03 z and he said after he put his test pipes on his light never came on either but i think i might have found the problem the exhaust gaskets were blown out so i put alot of gasket maker for temp til i can get some new gaskets but it didnt smoke as nearly much
Old Jan 2, 2008 | 02:27 PM
THE_SCHROED's Avatar
THE_SCHROED
hmmmm, that's odd that it would cause it to smoke. You sure it's just not the cold weather.
Old Jan 2, 2008 | 02:43 PM
Mazinger Z's Avatar
Mazinger Z
That's weird... does it smell like gasoline? Are your test pipes brand new?
Old Jan 2, 2008 | 04:12 PM
MDeezy's Avatar
MDeezy
white smoke normally is coolant related with a sweet-ish smell to it. so you have no power? but gained power?
What kind of gasket maker did you use? was it meant to be used on exhausts in place of gaskets? its possible your just burning those off and that is the smoke coming out. if anything take off the test pipes, clean off the gasket maker, put the old gaskets back on (temp) and see how the car is then. If anything the car should be a bit louder (maybe exhaust leak) but if there is no smoke it probably was the gasket maker.
or just order some new gaskets and install minus the gasket maker and see how the car is then
Old Jan 2, 2008 | 07:01 PM
surfer05rdr
since i put the gasket maker on which is only temporairly til i can get the old gaskets on it hasnt smoked yet, and since it started smoking i never lost power i only gained power. i marked my coolant level and im not burning any coolant at all so far. The test pipes are brand new. Also i could smell the smoke really well in the cabin of the car so i figured that the gaskets being blown out had alot to do with everything
Old Jan 2, 2008 | 07:28 PM
MDeezy's Avatar
MDeezy
order some new gaskets and you should be good to go. post back either way
Old Jan 2, 2008 | 10:25 PM
Mazinger Z's Avatar
Mazinger Z
Any rough idle you can notice? Like the car is about to die and then comes back?
Old Jan 3, 2008 | 03:00 PM
surfer05rdr
no rough idle at all runs just like it did without the test pipes just smokes, i ordered new gaskets they should be on by this weekend i hope that fixes the problem
Old Jan 3, 2008 | 03:05 PM
djclongisland
thank god 4 this thread i was freaking out just now... my caris idelig like ish, im sitting in it rite now, i just installed a new exhaust, all the same problems you are having.... what gaskets should i replace? i was so bummed i thought i had water in my gas or sumthin..... witch exhaust gaskets should i replace? also i noticed condensation in the exhaust.... gotta get sum gaskets 2moro
Old Jan 3, 2008 | 03:08 PM
djclongisland
my car is ideling rough too and its bogging like its gonna stall like the guy above me said, what does that mean?
Old Jan 3, 2008 | 07:41 PM
surfer05rdr
im replacing the exhaust gaskets that come off the headers to the test pipes, but ur problems sounds like it would be a little more than the exhaust gaskets. When u rev ur car up to about 5 can you hear it backfiring... how many miles is on your z
Old Jan 3, 2008 | 11:15 PM
djclongisland
no no backfireing, 36000, but this problem jsut started, i just put the exhaust on a few days ago
issyz
Jul 2, 2017 03:04 PM
codek
Sep 28, 2015 03:03 AM
